loader use
   / loader use #11
My neighbor showed me how to do this by putting the bucket bottom near vertical and pushing and pulling the gravel, but it involved going forward at quite a good speed and to the point the front tires came quite a ways off the ground each time he pushed the gravel forward or pulled it back.
That sounds like a great way to damage the tractor and/or loader. Do things slowly.
Lifting the tractor front end with the bucket is no big deal but doing it at speed? Bad idea.
A lot of blacktop you can get under and break it up. But the box blade with scarifiers is the best approach, or a bucket with teeth.
   / loader use #12
My neighbor showed me how to do this by putting the bucket bottom near vertical and pushing and pulling the gravel.
Your neighbor does not have a good grasp of what that sort of "bulldozing" can do to the bucket extension cylinders. There is a reason that your Kubota manual specifically recommends against such a method.
Wrooster
   / loader use
Thank you all VERY much. I wish my loader manual said something about this, but I couldn't find it. It certainly didn't give examples of using the loader as a dozer, hence my concern about this method. But, I didn't see anything specifically about it.
P.S., I found it in the manual, missed it first time
   / loader use #14
Even a 3 point mounted sub soiler would be a better choice for breaking up the roadbed. Then scoop it with the front loader.
   / loader use #15
Debp, that's a real good question. And Grandad4 is right. Here we have 4 tractors with loaders. The oldest is 40+ years old and they are all in fine shape. A good rule of thumb for using a loader is that it will be just fine with any job that it can do at a very low speed. The heavier the work, the slower you should go. Sometimes you are barely creeping forward. Don't ever be tempted to use speed instead of loader force and tractor power to force a loader bucket. That's how you will bend and break things. It may not break today, but eventually that will damage it.
You won't hurt the machine by creeping slowly into the job to evaluate it. Everyone does that. Just go very, very slowly. That gives time to see if the bucket is going to do the work or that the loader is under too much strain....... then it is time to get another implement out and break the project into smaller pieces.
Using speed to try to force the tractor to do something beyond it's capability is NOT the way to do things.
Luck, rScotty
I agree.
   / loader use #16
Ok, so by we know how to load a bucket. We drive up to a pile of material (slowly), select a low gear, and ease forward while wiggling the loader bucket to fill it. Front wheels can come off the ground doing this and that's OK. The key words are do it slowly and watch what's happening. Now raise the bucket and shake it to check and center the load, repeat if necessary, and finally lower the load nearly to the ground in order to drive away safely. Never ever drive anywhere with the bucket any higher than necessary. Dump slowly and repeat. Often it's easier to slice successive bucket loads from the sides of a dirt pile than from the center.
It's when the new dirt is roughly strewn over the driveway that the fun artistic part begins. I'll describe how I do it and maybe others will chime in with their hints too. Like a lot of old-timers I like to do the actual spreading, compacting, and smoothing by "back-dragging" with the loader bucket.
The best finished dirt surface is one that is compacted in successive thin layers with just the right moisture content. Soil too wet, too dry, or layered too thick won't compact. Of course anything works to some extent, but perfection is when the soil has just enough moisture so that a dirt ball can be squeezed by hand and will keep it's shape like a snowball does, and then spread and smashed down in successive thin layers. About an inch thick is all even a large machine can properly compact, and the compaction gets better with thinner layers and more passes.
To begin, I'll pull up with the bucket partway over one of those piles of dirt previously dumped in the roadway and lower the bucket with the cutting edge pointing down to slice off a bit of dirt. while slicing down, the front wheels will naturally come off the ground, and in this position I (slowly) back away a few feet to pull the bite free of the rest of the dirt pile. I'll continue backing away while simultaneously rotating the bucket up so as to flatten it as we spread the dirt on the road. By the time the bucket is nearly flat on the ground I am still backing up and still applying just enough down pressure to keep the front wheels a little off the ground.
Steering while backing with the front wheels off the ground is done by slight touches of the right and left rear wheel brakes. How nice it is to have found a way to use those individual wheel brakes that uses a delicate touch rather than standing on the pedal! With the wheels off the ground and the bucket flat it's poetry just how easily the wheel brakes can swing the loader bucket from side to side while backing...... just like icing a cake.
Enjoy! rScotty
   / loader use #17
^^^ Good info. I notice that you emphasized "slowly", LOL.
The idea of steering with the brake pedals is good, but usually needs a manual tranny AFAIK. It's hard to use the same foot on the HST pedal and the brakes :(
   / loader use #18
"Slowly" is sure a lot of what good tractor work is about, isn't it? And it's what makes an already durable machine last a lifetime.
Right you are! HST (hydrostatic) transmissions sure have complicated the wheel brake layout. It's interesting how some of the tractor brands are trying different solutions. When we were tractor shopping we noticed that JDs are laid out different from Kubotas, and that Case offered other options, ...making us wonder just how many different pedal and lever layouts are on the market today?
Mysteriously, the otherwise talented designers of our M59 put both wheel brakes on the right side of the steering column. Good intentions maybe.... but NOT a universal solution. For some it might work OK, but older folk generally find that layout awkward since it makes swivel seat brake pedal gymnastics necessary and also moved the HST pedal outboard to a less comfortable position.
I'm guessing that those lucky Kubota engineers conveniently born with three right feet and one left found the M59 pedal layout no problem regardless of age. For them it's perfect. For the rest of us it's gymnastics 101 revisited with a yoga twist.
To Kubota's credit, somewhere in the design process someone did figure out that many (most?) of the intended M59 customer pool had been born with a different anatomical layout than the design engineers had counted on. So after making the embarrassing mistake of miscounting the number of feet per customer, Kubota corrected the problem by adding extra hand levers to control the HST.
With enough hand controls, even us two-footed folk can work the HST and brakes at the same time.
Enjoy!! rScotty
   / loader use #19
My 2 cents.
Most if not all already said PLUS
NEVER ram into something! always ease in gently and then add power. Let hydraulics do the work.
TOOTH BAR is your best friend. Makes a whole new machine. Digging, rakeing, clearing roots etc, only downside is back grading a smooth finish but then the tooth bar gets removed for that.
   / loader use #20
I had poor results from the JD toothbar on my skid steer. Poor design, it kept breaking the corner teeth off (they were weakly welded on). I gave up and bought a Blue Diamond tooth bucket. The teeth do not hang below the bucket so it backdrags smoothly, the best of both worlds, good digging and good backdragging.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
KUBOTA LA525 TRACTOR (A59823)
KUBOTA LA525...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
