Restoring old barn Timbers
/ Restoring old barn Timbers #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
We have torn down two barns that are 90-100 years old and removed as many hand hewed timbers as possible. A couple of them are 21ft long and as new but most are weathered and have minor rot and or bug holes toward the surface. All but 2 are 8x8 oak post and the 2 are 11x11 oak. How might i go about getting these cleaned and ready to use in the interior of a new home construction?
/ Restoring old barn Timbers #2
This is typically done by running them through a planer in order to remove a small amount of material and also to size them consistently.
/ Restoring old barn Timbers #3
Pressure washer or wire wheel on a grinder or wire brush.
Might want to spray them with a Boracare to help prevent further decay and insect damage.
/ Restoring old barn Timbers #4
How will you be using them, as timbers, or will you rip them down into boards?
/ Restoring old barn Timbers #5
If you want the appearance of bright rough sawn lumber, find someone with a good bandsaw sawmill, that is particular about their work. Dad sawed many barn beams for a local building contractor who salvaged old barns. He would saw 3/8" off the outside of the beam, which the contractor used for real wood paneling. The rest was sawn into hardwood flooring.
/ Restoring old barn Timbers #6
Might be able to sand blast them using a very fine medium/powder. Have seen it done for homes in Colorado using walnut or pecan hulls too.
/ Restoring old barn Timbers #7
Try bleach on a piece and see how it comes out after it dries for a day or two. I know a company that bleaches new post and beam houses.
Ive considered plaining them down but problem is they are hand hewed and i really want to keep this appearance as my great grand parents did the work. I see some very small holes in certain areas so figured bugs were or are in there now. I will use these in basement man-cave and 2 for front porch of future new home.
/ Restoring old barn Timbers #9
I don't blame you for wanting to keep the look of the boards. Why not just treat them for bugs...then put a light varnish on them. Would look great on a wall.....just make sure the bugs are gone! Good luck...:thumbsup:
/ Restoring old barn Timbers #10
I am glad you want to preserve the hand work of your great grandparents. You cannot replace such treasures.
/ Restoring old barn Timbers #11
^This is the way to go. Fine glass bead or baking soda is not too agressive.
What is something good to use to treat for bugs? Since they will be in the house i want to make sure its safe to use.
Thanks
/ Restoring old barn Timbers #13
Thanks
What kind of bugs? Around here we have boring beetles in old timber. Not something to be ignored.
/ Restoring old barn Timbers #14
I own a cabin that was remodeled, and the former owner used a couple of old barn beams that look
great. They were never sealed or sanded. -- still can find some bird do do on them. -Well the problem is
what they call powder post beatles. These will leave very small holes in the wood about 1/32" in dia.
When they feed on the wood they leave very fine sawdust the we find on the coffee table ect. --- Each season there is a hatch of adult beatles that can fly, they don't bite and we just vacuum them up, they only hatch for about two weeks. ---I have watched an episode of this old house where they discused the same problem. They talked with an entomologist about how to rid the beams of the beatles. --- They desided to heat the beams to 160F and keep that temp for 24 hours so the heat would penatrate the beams. They built a vis-screen tent out side and with a salamander heater with a thermostat they did it. --Made sense to me. ---- I have thought about starting up the wood stove and stripping down on a hot july day!! Ha --Good luck
/ Restoring old barn Timbers #15
There is a treatment for insects in the timber such as powder beetles.
http://doyourownpestcontrol.com/timbor.htm
I don't know about having this done in your house, but I had it done in an exterior building.
/ Restoring old barn Timbers #16
I used to restore wood decks and would use Wolmans Deck Bright. It is a peroxide based cleaner and bubbles up and raises dirt and weathered wood off. Rinse with a pressure washer and it will look like new wood but will still have it character. I brought decks back to life that the owners gave up on years before. Give it a try and you will be amazed.
/ Restoring old barn Timbers #17
/ Restoring old barn Timbers #18
/ Restoring old barn Timbers #20
Timbor is Disodium Octaborate Tetrahydrate. Not exactly the same as Borax. Timbor is an insecticide. The chemical makeup of Timbor is Na2B8O13.4H2O and Borax is Na2B4O7.10H2O.
Any concerns on barns and sheds?
