Iseki TX2160 hydraulics
/ Iseki TX2160 hydraulics #1
neilm
Nottingham, UK
Iseki tx2160
Hi all,
Just bought a little TX2160 mainly to do some mowing at home. I bought it as a non runner that had sat around for about 5 years, I have managed to get the engine running and replaced all the oil & filters but I've got a problem with the 3pt hitch.
The hitch raises and lowers as it should but as soon as I put some weight on it, it won't lift. With full revs, it seems to have a bit more power but it still won't lift anything i.e me! I've cleaned out the suction filter and put in 80W oil but no joy. I suspect the pump is probably ok but I can't test it at the moment, if I take off the high pressure line and crank the engine then fluid does come out ok.
I've attempted to remove the top hydraulic case above the gearbox to see if there is anything caught in there but I can't seem to get it out. I've undone all the bolts and the head moves about 0.5cm but no further, am I missing something?? I've ordered a service manual but that may not arrive for a week or so.
Any thoughts greatly appreciated.
Neil
/ Iseki TX2160 hydraulics #2
See if the link below works for you - came across this when I was looking for a parts manual for my own tractor.
Round about page 105 is the lift arm unit, looking at the diagram may just give you the info you need. I just lifted mine off my TX1500 - looks to be exactly the same unit. Have you taken off the distribution/valve block - there is a bolt under that. Also one under the top-link bracket if you missed that. Mine still took a little bit of persuasion to come off once all the bolts and nuts were free.
ftp://ftp.rapid.ch/Iseki/Traktoren ...e de pieces Spare parts list/TX2160 ET GB.pdf
Thanks dantz,
If you happen to have a copy of the service manual too then that would be great? I've ordered it but that's not going to arrive soon.
I've managed to get the case off the gearbox now and can't see anything obvious that's causing the issue. I'll clean everything up and see if that makes a difference. The pressure relief valve could be an issue as it looks to me as though it's stuck open. Would that cause the lower pressure to the hitch? I would have thought that the hitch would drop when I turn the engine off if it was flowing back out the valve?
/ Iseki TX2160 hydraulics #4
Don't have the service manual, for some reason no copies online yet despite being 30+ yr old tractors.
If the pressure relief valve is passing then that is your problem, only briefly looked at it on mine, I'm sure its not isolated from the lift piston, so the hydraulic piston will only develop enough pressure as a the flow restriction through the safety valve allows. It will be enough to move the arms with no load and probably hold under there own weight. You have to ask the question why is it stuck open though, so if you manage to reseat it, then be careful as you load up again.
/ Iseki TX2160 hydraulics #5
The Iseki TX2160 is basically the same as the Iseki TX1500F & a Bolens G174 ( the only major difference is some eralier machines use a 2cyl engine & later machines have a 3cyl - most other items are interchangeable or "will fit")
Sounds to me that it might be a simple case of needing to bleed the air from the hydraulics :-
/ Iseki TX2160 hydraulics #6
If the lift arms are up, you have fluid in the 3pt cylinder.
When you lower the lever to lower the arms, you allow the fluid to drain back to tank.
The descent knob will control the drop rate.
If the relief is stuck open, then some of the fluid will bypass.
If you have a loader, then install a 3000 psi hyd gage in a tee in the IN port of the FEL valve, and then you can monitor and trouble shoot the hyd system.
Anytime you use the loader, you should see the pressure developed by the loader cylinders.
If no loader, then install a tee with hyd gage after the pump where you can see it .
With the gage installed, anytime the tractor is using hyd, you will see the pressure on the gage.
So if you pull the handle for 3pt, you will see some pressure, and when you max out the 3pt cyl, you should see relief pressure.
Check and clean the relief valve.
Any air in the system will self purge as you use the hydraulics.
If the lift arms falls over time, or you can't build up pressure, then the seals on the 3pt cylinder could be worn or brittle.
Thanks for the help so far.
Bit of an update but still no joy from it at the moment. There is no bleed screw on this model, I think it purges as it goes as JJ has suggested.
I've cleaned the spool valve and the relief valve too. The relief is working properly I think, when it's wound out the hitch does not raise but when wound in a bit it lifts the hitch but again, not when i put any weight on it. I don't want to close the valve too much as i don't want to risk the pressure getting too high. Is there any way of knowing how to set this without a gauge?
JJ the hitch does not drop over time, if i leave it overnight they are still raised so I've ruled out the cylinder now and suspicion is now aimed at the pump being clogged up. I will try and order a gauge next week as I think I'm stuck without one unless there is an easy way to work things out without one?
One thing to add, earlier when I put everything back together, it started to raise the hitch with weight on it for about 10 seconds before failing again. Not sure if that points to anything??
JJ - I just got hold of a gauge and it's showing around 500 PSI when operating the hitch, does not appear to change when the hitch is raised so I'm still not really sure if the pump is not putting out the pressure or if the relief is open. Is there any way of telling which is causing the issue?
I was going to put a valve after the pressure gauge and slowly close it (not fully) to check if the pump is working or if it's an issue elsewhere. Other option will be to clean out the suction line incase of a blockage in it. Thoughts appreciated.
/ Iseki TX2160 hydraulics #9
You'll need to "stall" out the 3-pt arms to check the relief valve pressure. Just find something that you cannot lift with the 3-pt and see what your gauge says. WARNING: IF YOUR RELIEF VALVE IS NOT OPERATING CORRECTLY YOU COULD DAMAGE YOUR HYDRAULIC SYSTEM. There, now legally I'm off-the-hook :)
/ Iseki TX2160 hydraulics #10
My 2160F is equipped with a "position control" type of 3-pt hydraulic. Not all of the TX1500s had this so there can be a difference in this area as well.
Just another update if anyone has any thoughts or pointers.
I plugged the gauge into the pump output and it was showing around 500PSI regardless of lifting the hitch or not. I've now plugged a shutoff valve after the gauge and it was showing around 1500psi after closing the valve a bit. This leads me to suspect the pump is fine and able to get upto pressure. So the problem is upstream of the pump, I'm happy with the cylinder as the hitch does not drop with the engine off.
The downside is that I'm now stuck. I've cleaned the relief valve ontop of the cylinder and it looks to be working as far as I can tell. Stalling the hitch does not make any difference to the base 500psi pressure.
I suspect now that I've got a leak somewhere, possible the spool valve? I've taken it to pieces and cleaned it all up, can't see anything that looks wrong. There appears to be another relief valve on the spool, again it looks ok to me.
Any thoughts appreciated.
Thanks
/ Iseki TX2160 hydraulics #12
Hi,
Sorry to hear that you are still having issues. Attached are the only two pages from the service manual that I have about the hydraulics. I wish that I had a better understanding of the hydraulics to help you more, but I usually have to refer to the manual when it comes to the 3point lift. Can you possibly use a mechanics stethoscope to help find the leak? Anyways, I hope that this helps a bit. Sorry for the poor resolution...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
Genie GTH-844 (A64126)
AGT SAII100 (A64127)
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
John Deere 772-A Grader (A62679)
John Deere 772-A...
