2014 Chevy/GMC specs
/ 2014 Chevy/GMC specs #1
Dmace
Elite Member
Wakefield, NH
Kioti CK20 HST
Looks like GM released some specs on the 2014 1500 trucks.
http://news.pickuptrucks.com/2013/0...53l-mpg-power-payload-and-towing-numbers.html
V8 5.3l direct injected, normally aspirated, EcoTec making 355 HP / 383 LB.FT. burning 87 octane with no turbos or drivetrain tricks. Nice flat torque curve plus still has that V8 sound.
4x2 - 16 city / 23 highway / 19 combined
4x4 - 16 city / 22 highway / 18 combined
11,500 lbs max towing capacity
2,102 lbs max payload
The 6.2l EcoTec will be a monster!
Here come the anti-anything-but-Ford stories...
/ 2014 Chevy/GMC specs #2
That 5.3 makes good power, especially on 87 octane.
/ 2014 Chevy/GMC specs #3
Not bad numbers but I was expecting a little better power and tq. Fuel economy should improve more with the 8 speed. I'm anxious to see the V6 numbers moreso then the 6.2.
/ 2014 Chevy/GMC specs #4
I am surprised the mpg numbers are not better. It makes less power then the competition and gets the same economy. They had a chance to really do something here but are keeping the typical following and that's good enough attitude.
Either way I Will not buy GM so it really does not matter to me.
Chris
/ 2014 Chevy/GMC specs #5
Chris
Exactly. It's like dating the girl that all your friends have already dated and you strut her around town like she's something special. I don't see how they are going to keep up with Ford and Ram. The new Titan might even blow them away. They needed these numbers in 2011, not 2014.
/ 2014 Chevy/GMC specs #6
This is the best V8 fuel economy right now i believe.
This isn't the top or bottom engine. It matches the 5.0 in power and blows it away in fuel economy.
It even beats the EcoBoost in fuel economy.
I'd imagine the 6.2 will wipe the floor with the others.
For a mid-level engine competing with Ford's 5.0l V8 (360hp/380lb.ft.) it's right where it should be in my opinion. Don't want to make it too close to the 6.2l.
I'm also curious to see how the smaller V6 4.3l will compare to the 25mpg RAM Pentastar V6 3.6l (305hp/269lb.ft).
I knew these larger direct injected engines would be good.
/ 2014 Chevy/GMC specs #8
I bet it make less power but more torque.
/ 2014 Chevy/GMC specs #9
That's the problem. All Ford has to do now is sprinkle a little "magic dust" and up the power, tq, tow rating and fuel economy. I was hoping they'd make Ford have to sprinkle a whole bunch of dust at least. The v6 is going to be offered in crew cabs with 6' beds as an option I believe. That's what has me anxious.
Yeah, probably closer to the RAM V8 4.7l (310hp/330lb.ft - 14 city/20 hwy) but with much better fuel mileage.
True but I doubt there's much left in the Ford engines without major changes or loss of fuel economy. I see the revival of the V8 5.4l with direct injection coming...
Now RAM needs to hurry up with that V6 diesel release!
/ 2014 Chevy/GMC specs #12
I agree.
Chris
Which engine are you comparing it to?
It gets BETTER economy than the competition. Plus I gaurantee the fuel mileage while towing will be much better than the Ecoboost.
/ 2014 Chevy/GMC specs #14
To some here, no matter what GM does it's dismissed out of hand but everything Ford does is perfect and to be worshipped...That's pretty much why I really don't pay much attention to this thread anymore...It's a relentless anti-GM diatribe on every subject. It has grown beyond tiresome.
/ 2014 Chevy/GMC specs #15
Again you don't know what you are talking about.
/ 2014 Chevy/GMC specs #16
These are certainly interesting points. However who is to say that GM did release be very conservative to these engines? I wouldn't be at all surprised if there's plenty of power left for GM to dial-up on these engines.
Again you have absolutely nothing useful to add..
I agree.
They're typically pretty conservative with new engine releases.
/ 2014 Chevy/GMC specs #18
How about this then, the 5.0 is already getting that combined mileage without DI and makes more power. I think the 2015 F-150 will exceed the Highway mileage numbers.
No it's not, the 5.0l is rated at:
4x2 - 15 city / 21 highway / 17 combined
4x4 - 14 city / 19 highway / 16 combined
V8 5.3l
Even in 4x4 the new GM 5.3l beats the 2WD 5.0l I still say the 5.0l is a good engine though and if Ford goes to an aluminum frame, mileage will go up but so will price.
/ 2014 Chevy/GMC specs #20
If the read world numbers prove these number correct then good for GM. But I have to think that GM's money woes is why they are sticking with a push rod V8 vs multi-cam more valves per cylinders. Who else is using cylinder shut down to get higher EPA numbers? If nobody then I would expect that all the other brands will add it just to boost their numbers as well.
2015 Deere 210G (A64126)
2015 Deere 210G...
John Deere 6125R (A60462)
John Deere 6125R...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
