R4041 Loader Issue LB4101
/ R4041 Loader Issue LB4101 #41
My 7274 had a 417 loader which is the same as a Woods 165. The 7300 has a 476 loader, which is the same as a Woods 1009.
That front axle has for its outer wheel bearings, a ball bearing with 8 balls in a riveted cage. Too much weight pushes the balls apart so hard that it blows the rivets out of the cages. I have seen this failure four times.
The weights that I busted stuff with were trees and logs. I wonder how hard it would be to upgrade the front drive to a beefier one. It's too bad the LS is the smaller, weaker, loader, as its front axle looks way hunkier.
I also have foamed front tires on the Cub, which is also supposed to be hard on front drives. I do like to look at the nail heads sticking out of those tires though.
/ R4041 Loader Issue LB4101 #42
So are you saying that the 2500# lift & 4354# breakout are OVERrated? Those specs are higher (on paper) than from what I've seen from competing size tractor/loader combinations from other manufacturers.
I agree that the maximum height of the lift is lower than competing loaders, but it's more than my last loader, and I had no issues with the height of that as it was.
For S&G's, I was just looking on the LS site for specs on the u5020. The tractor is obviously bigger (a couple inches longer, wider & taller).... The loader specs (LL5100/5102 loader) for weight are not much higher than the LL4100/4101, but the lift height dynamics are MUCH better; Roughly 20" higher! The hydraulic flow is also about 20% higher.
/ R4041 Loader Issue LB4101 #43
Getting irritated with my loader now:
Used it for a couple hours today moving some dirt. Nearly every time I get to full dump, the rollback goes limp briefly. It takes me 3 attempts of "side-to -side " on the joystick before the bucket will actually "shake", getting the rest of the dirt out.
Here's an example:
https://www.youtube.com/watch?v=JJIi46w3icQ&feature=youtube_gdata_player
I'm going to call my dealer tomorrow and see what he has to say about it.
/ R4041 Loader Issue LB4101 #46
Boy, that chicken sure moved fast!!
/ R4041 Loader Issue LB4101 #47
:D anytime I get the tractor out, they follow me around to forage in the fresh dirt. They had a field day today as I turned over alot of grass, but the idiots get so dang close to the tractor, it's a wonder I haven't squished any yet.
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
213086 (A64276)
213086 (A64276)
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
Generac Speedwash Pressure Washer (A65640)
Generac Speedwash...
