First timer- field prep for field grass
/ First timer- field prep for field grass #21
Looks nice. Both the seed mixes mentioned sound good and the one with alfalfa and clover would be high nutrition factor feed for the horses. How are you going to smooth and pack the soil when you seed? I've seen everything from a log chained cross-ways to roller packers etc.
Finally, just went down to the extension office (couldn't find a phone # ) and talked to the gentleman , about soil analysis- didn't remember that an extension office is part of the university not so much a state office?. Anyway he was very helpful, got the soil mail in kit , the cost is $35 and will tell ph ,whether we need phosphorous ,nitrogen ,lime, other things... and also got a flier, about the invasives- wife already found two more plant species that we will want to eradicate... Also working on a (bandaid fix) for the old 3 point tiller, if I can get it to run will sure help with the field corners and other tight spots..The extension office is time well spent, would highly recommend this step for people like us- that aren't well versed in field health. will post new developments as they happen
when you mentioned a log chained cross ways- it brought back old memories.
When I was 16 my dad owned a 230 acre ranch and we had to level a couple of the larger fields ,dad had taken 3 full length telephone poles and cabled them together in a Z pattern. We had a Case 970 AGRI-KING tractor- it was the first tractor I ever drove and put a lot of hours on.
Any way he had me out in the largest field pulling that big phone pole drag around ,I had my eye on the horizon and after a while it seemed like the tractor wasn't moving as fast although the engine hadn't slowed down one bit.. I looked back at the drag and it had pulled up almost 12" or so of dirt over the top all three logs the entire length of each, the tires had dug trenches all the way back to the drag and the rear axle was just about to touch the ground.. it took quite a while to kick off all the dirt, unhook the tractor re position it and get moving again. I found a new respect for that big Case tractors power that day- all that weight and dirt and the engine didn't even notice! but I digress, back to the thread
Dug this up today, spike harrow 003.jpg pretty small but it might work to break the clods down, maybe look into the drag idea, built one out of a pallet and 2x6s for the area where my garage was to be constructed , will try to check it out tomorrow, the alfalfa sounds good ,that stuff is sure getting expensive to buy- at least here, but that is a plant it every year seed I believe
/ First timer- field prep for field grass #24
Field is lookin' really nice! :thumbsup: Couple of observations.. especially with regards to pastures and horses. Alfalfa and clover are problematic for horses. Your extension folk's can also help to verse you on this subject. Some species of clover are very bad for horses and alfalfa is too high in protein to be included in the horses diet at a high %.
Secondly, one of my first pastures (actually 2) I had a nice fallow seedbed; planted everything the first week in November - 6" of new snow a week later. Got great germination the next Spring and a beautiful stand! Waited until early fall before I ever let the horses put a foot on those fields.
Dang... they punched holes everywhere in those fields! :eek: I had already mowed the grass once, maybe twice, earlier in the summer and hauled the clippings off. The grass was probably 4" maybe 5" tall. Figured that the roots were solid enough... Nope, not even close - about every 10th mouthful - they'd pull the whole clump of grass up! Crap!!
Long story - short. I ended up dragging the fields with a short-tined drag, reseeded (overseeded) and roller-packed - ROLLER PACKED - those fields with a 8' - 3,800lb water filled roller.
You gotta pack that field. Seriously. They'll make it look like World War I out there...
AKfish
AKfish
Already caught **** from the wife, after she looked at my post about the alfalfa, was considering closing that field off and trying to harvest the alfalfa, but she just told me that ain't going to happen either:laughing: I told her no matter what gets seeded there 's not going to be any horses on it either at least till it has had a chance to grow up good, she also said some of the other fields already have enough clover and something about the horses mouths going numb,(think thats what's happening to my head):muttering::laughing:
any way I'm going to send off the soil sample in the morning and after walking on the field Definitely agree somehow going to have to pack the field eventually... My sister still has several implements , and a JD 550 crawler,bet that would pack it down, if I ran it up and down the field? not sure if my trailer or hers will haul it though,seriously doubt it -maybe I can rent a roller when the time comes... You've got me thinking....:)
/ First timer- field prep for field grass #26
AKfish
That's a new one to me but you learn something new every day. Growing up the team got hay that was a mix of Timothy , orchard grass and red clover. No problem that I recall. The only thing we had and still have here is a low fern my father called polliwog breaks that grew on wet poorly drained soil. It was poisonous to horses but they would sort it out of their hay and leave it in the end of the manger unless they were starving.
My father also had a drag for smoothing up ground and setting in the seed. About twelve feet wide it was made of rough sawed two inch planks with the front 2x8 turned up 45 degrees and a 2x6 top in the front top . It had two interior bulk heads plus the ends also made from 2x8. The chain went through the third points and through a hole in the bulkheads and made an A to the teams evener clevis. To use it you stood in it using the driving reins from the team for balance. Be shifting your weight side to side and front to back you could keep it pretty much square and riding over the dirt like a boat on plane going over a pond. The first pass over plowed and harrowed ground would do a good job of filling in hollows and scalping high spots so you could mow it later. Then broadcast your oats and other seed and make another complete pass to set the seed. Never had any trouble with the horses punching it up later but this was well drained land good for growing strawberries and potatoes as well as hay. In June the next year the Timothy was as tall as the horses backs (Percherons).
/ First timer- field prep for field grass #27
Red clover is fine for horses. White clover is not. If today's horses worked half as hard as Percherons of a 100 years ago... well, 50% alfalfa would be just fine. But, we all know what happens if you eat ice cream all day and watch TV!
It's cool in Alaska.. even in the summer time. Temps in the 70's is what we have in June-July. Once in a blue moon, it'll jump into the low 80's and you'd swear that eggs would fry on the highway! :laughing:
So, my pastures never, really dry out. I mean dry, powder dry - like I remember from days in South Dakota. So, if your pasture isn't solid, with a real good sod cover - horses will just destroy it! And if you don't get 'em off of it when it's really wet and raining... well, you'll get plenty of experience re-doing the field.
That said, northern latitude and mountain areas have similar environments to Alaska. Tend to be wetter in Spring and Fall with cooler average temps and shorter growing seasons. So, I'm bettin' that sd455dan would have pastures not far off the mark from what I've got. He's likely to have 6 weeks (3 weeks earlier in Spring and 3 weeks later in Fall before frost) more growing season than I've got and his summer high temps are probably 10 degrees warmer on average (low to mid 90's high in summer versus low to mid 80's).
I'd still pack those pastures... with somethin'!
AKfish
Today- was going to send the soil sample off but it has to be dry, and you can't use artificial means to dry it ...will send it off tomorrow.
worked on the tiller and I think it will run at least for the corners and such...still looking into how to pack the soil...and the summers are about like AKFISH stated -still to much winter ...for me sometimes:)
/ First timer- field prep for field grass #29
Red clover is fine for horses. White clover is not. If today's horses worked half as hard as Percherons of a 100 years ago... well, 50% alfalfa would be just fine. But, we all know what happens if you eat ice cream all day and watch TV!....
AKfish
Well it wasn't quite a 100 years ago. The last time I hayed the place with the horses was 1973 when I was eighteen. It was hard work for both the horses and me. When you would stop to grease and oil the six foot cut IH mower the sweat would be dripping off the bellies of the horses like a leaky faucet. Except for race horses in training you seldom see a horse lathered up like that today. You'd start them out slow by doing a little logging first to get them back in training before hooking on to something they could break and let them build up muscles like any athlete. The muscles on their forelegs would bulge like a body builders biceps. No cab and AC on a horse drawn mower. Bees were fun to.
/ First timer- field prep for field grass #30
I've got a few years on ya - but your experience's with workin' horses are way outside anything I've ever done with horses! But.. I have seen horses pretty lathered up packin' out moose hind quarters or caribou, though. And ground nesting yellow jackets up here will get you and your horses into a genuine panic... GENUINE - right now! :eek:
AKfish
/ First timer- field prep for field grass #31
AKfish
I've had a whole moose pulled out with a horse, just a 500 pounder. Worst I got with the yellow jackets was raking up a good sized nest with a dump rake and getting it stuck impaled on the tine right under my seat. It took four dumps to shake it off and the team which was normally pretty calm as they were both old enough to vote took me across the whole field at a gallop and broke the pole on the first tree they came to. I bounced off one of the horses rump and managed to not get kicked by their very busy hind feet.
Time to ask for some more information , hopefully you and AK FISH have some more Knowledge to throw my way. that soil sample was finally dry enough on Saturday morning but I missed sending it off (working on tiller) so when it goes out tomorrow it will probably be at least a week before the results come back...
Sooo while I am waiting is there anything I should do to the field, Oh also in the last 3 days I got the old 3 point weight out (85 " chinese tiller) and did get it working , but going forward it shakes like a shopping cart full of soup cans going down a flight of stairs, running the tractor in reverse it is very smooth, I jacked it up and supported it pressure washed it and it appears there are a few broken and bent (tines or Knives) anyway going to straighten and replace the central damaged ones with the ones from one outside, mount- then sharpen all of them and see if this fixxes the shake...
Now the question- what should be done to the existing field next, am I stuck until the report comes back, does the field need to be either disced, or tilled to more of a powder, if the field needs some kind of fertilizer is it better to have the field more worked over or less...
There is another horse field my wife wants to work on, it needs all the pine needles raked up (I have a 3 point rake) then I can run the disc -find most of the tree roots, and maybe do a lite tilling of it and just overseed with the northwest horse pasture mix. Her plan... while waiting for results.. All suggestions are welcomed:)
/ First timer- field prep for field grass #33
You need to replace the broken blades for it to be in balance and work right. Also you might have a bearing worn out causing the shaking. You should change that out before you do more damage to the shafts.
You could jump the gun on your soil test and assume that you need at least one ton per acre of lime and round that up and get it spread. If no spreader is handy you can just spread out the 80 lb bags so they are 40 feet apart each way and break them open and spread with a shovel broad cast. Another pass with the disk will mix it in and even things out while further smoothing and preparing your seed bed.
/ First timer- field prep for field grass #34
Not sure if the timing works out for your grass planting, but if you can let the field set long enough for any weeds to germinate and sprout, then re-disc it to kill those before seeding.
/ First timer- field prep for field grass #35
Most soils that were originally forested tend to be acidic. They need lime. How much is a local/regional determination - your local extension folk's (or your neighbor) will have a good idea (ballpark) until you get your soil test results back.
vtsnowedin and dave1949 have some good ideas regarding the lime as well as another pass with the disc after the weeds begin to green up a bit.
Pastures or hay ground doesn't need the same kind of soil prep as a vegetable garden or even a lawn. IMO - another pass or two with the disc and as long as you don't have sod clumps or large clods (fist sized or larger) I'd bet you'd be just fine seed-bed wise and if the tiller is a no-go: you won't really need it.
The first time or two that I worked; re-worked my pastures I worked everything to a fine puree... overkill and a waste of time, fuel and $$, too. The last time, I had small lumps, bumps and clumps - everything sprouted up and the horses never even noticed! ;)
AKfish
/ First timer- field prep for field grass #36
Pastures or hay ground doesn't need the same kind of soil prep as a vegetable garden or even a lawn. IMO - another pass or two with the disc and as long as you don't have sod clumps or large clods (fist sized or larger) I'd bet you'd be just fine seed-bed wise and if the tiller is a no-go: you won't really need it.The first time or two that I worked; re-worked my pastures I worked everything to a fine puree... overkill and a waste of time, fuel and $$, too. The last time, I had small lumps, bumps and clumps - everything sprouted up and the horses never even noticed! ;)
AKfish
Very true. Anything you don't get perfectly flat will get treaded in by the horses in short order.
Ok so fist sized clods are fine , Finally got the soil sample off to the University analysis lab, the post office clerk thought the lab would receive it today. Helped the wife clean up the pine needles in her horses field, I raked them up last fall and just can't believe how many were on the ground this spring! and about 1/5 of the pile is on the left in the field,Salaras field -pine needle removal 001.jpg already hauled several grapples and buckets full there are a couple piles not in the picture to get still! once I got rid of most of the pine needles decided to try a test run down the middle with the working for now Tiller- Straitened blades made sure they were evenly spaced and sharpened , seems to be fairly smooth now (no play in the auger)Salaras field -pine needle removal 010.jpg Think Tomorrow will try to (work on this field) run tiller in the open spaces , lightly disc and then the wife may just over seed with pasture mix. Should be interesting to compare the two areas before winter. Although this one is probably acidic and I don't know if she is going to allow the horse on it
/ First timer- field prep for field grass #38
Your tiller is workin' real well! Lookin' very good.. It doesn't need a whole lot more - seed, fertilize and pack. Wait for rain and watch it grow.
AKfish
Well I still haven't got anything back from the university on the soil sample, so today I went a head and worked on the horses field, my wife wanted (finished) this is the field that was recovered in pine needles. So I took the disc to it. Then got the tight hard to get to places with the rhino and tiller, back to the disc and here's where I ended on this field..tilling and discing 005.jpg still working on a plan for a roller or compactor..
We had this little pen, that last year had the most weeds of anywhere on the property, and since it was so small I just hit it with the tiller after removing the branches from a blown down treetilling and discing 007.jpg R E A L L Y like having a working tiller (worked this same spot last year with a box blade (all day)) and didn't accomplish much tilling and discing 009.jpg anyway-tilling and discing 011.JPG will let everyone know what the soil sample says and go from there :thumbsup:
/ First timer- field prep for field grass #40
I've really enjoyed this thread & look forward to the results & advice. I too am about to start improving my paddocks for horses... they've been fallow for over 20 years (I've been an 'evil' landlord whilst serving in the Navy) and the soil is poor because of it.
I've 'clubbed together' with the neighbours to get the limers out to us before winter (seasons are opposite down here) and I'm going for 2 tonnes per acre. I've already chain-harrowed the horse manure onto the paddocks to be worked. Fertiliser/seed mixture will be tilled in, but I didn't know about packing it down. Great advice, Ta.
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2022 GEHL RT215 SKID STEER (A65053)
2022 GEHL RT215...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
