bush hogging ("rotary mowers") advice please
   / bush hogging ("rotary mowers") advice please #11
Check out the HOWSE brand of cutters. I had a 6 foot economy model duty (601S model I think) that I put thru H3ll with a 45 HP tractor and never had a problem with it other than hitting big rocks and throwing them into the light sheet metal sides which put some dents in the sides. As far as the components, I don't think there is much difference in the lightweight gearbox, stumpjumper or blades. It seems that the major difference is in the sheet metal thickness. My light duty one had a 75 HP gearbox but the sheet metal was 12gauge (less than 1/8" )and weighed only about 600# whereas my current heavy duty bush hog 7 foot one is 1/4" sheet metal with channel side frames and weighs over 1500#. I cut trees with the Howse that were 3-4" thick, basically anything that I could push over and drive over, I cut and never even sheared a pin but stalled the engine on my tractor a few times. I only gave $800 for my Howes about 4-5 years ago. I think that would be plenty heavy for anything you will cut on 6 acres and pull with a 30 HP tractor. Keep the deck cleaned and painted to prevent rust thru which is what gets the sheet metal in the light duty models. Storing it under a shed will make it last much longer. If you don't have a shed, just block it up off the ground so it can circulate air underneath will help also. I am sure they are higher now than what they were 4-5 years ago but were a good buy then and they are made in Mississippi, USA.
   / bush hogging ("rotary mowers") advice please #12
I know that some people prefer to buy new, and if you're one of them then disregard this, but I wouldn't buy a new rotary cutter. The first reason is that, no matter what you do, it's going to get beat to heck pretty quickly, so that "new car smell" won't last long. The second reason is that they are probably the single most common tractor implement I see for sale used, so a buyer pretty much has his pick. $1600-$2400 for a new 5' cutter?!?! You can pick up a used, but perfectly functional one for $300-$600, easily.
Here are some suggestions:
6 foot Rotary Cutter *Bushhog*
6' rotary cutter, $475. The paint is a little too clean, so check to be sure this isn't a beater that has just been dolled up. If the gear box and PTO are tight, this is a steal.
5 foot bush hog
5' cutter, $350 OBO, so maybe you can get it for $300.
Bushhog (brand:bush hog) SQ60- 5 foot
Actual Bush-hog brand squealer, 5', $450.
And if you're concerned about longevity? Heck. You can buy 4-6 of the used ones for the price of a new one, you know?
   / bush hogging ("rotary mowers") advice please #13
I tend to agree with Joshua on a good used unit if available near you. Atleast to clean everything up the first time or two, amazing what you can find with a brush mower evon on your own property. The third listing for the 60" squealer looks okay.
It looks like that "squealer" has been pulled from Craigslist.
Thanks a ton for those links... very cool of you to do quick assessments of each one!
5 foot bush hog
   / bush hogging ("rotary mowers") advice please #15
Regardless, the understory is full of weed, invasive privet trees/shrubs and honeysuckle (I'm in Tenn.)
Almost everything is going to be under 2" thick... I'll pull the bigger stuff out with the shrub grubber.
I would plan on buying a sprayer, too. You will get regrowth of the privet that you bush hog.
Steve
Thanks... about the regrowth of privet.
Dang. I have been thinking about that. Was hoping to retain some of the ground cover (ivy and vinca).... but won't be able to do that if I resort to spraying.
The honeysuckle is bad, but not nearly as persistent as the privet.
Wondering if there is a way I can "paint" the weed killer on the privet itself and preserve the ground cover.
In the end, I might just resort to just mowing the privet every so often... in that case, I'll try to cut rather high so as to preserve the groundcover and increase the safety of the box turtles.
   / bush hogging ("rotary mowers") advice please #17
   / bush hogging ("rotary mowers") advice please #18
If Western Kentucky is not too far to drive, I changed tractors recently - allowing me to go from a 5 footer to a 6 footer. I was not offered as much in trade as I think it's worth, so my 5 foot Kodiak MD60 is available. It's as depicted in the attached page; with optional slipclutch, but without chains. Didn't want them, cuz chains on a previous RC clogged and tangled badly. Only been use two seasons for pasture maintenance, so the blades don't even need sharpening yet.
You should be able to get rid of the privet without damage to the underlying grasses with 2,4-D
//greg//
   / bush hogging ("rotary mowers") advice please #19
//greg//
I have the same Kodiak mower and it's worked out great for me. I have no complaints.
   / bush hogging ("rotary mowers") advice please #20
I also prefer slip clutch over shear pins. At the beginning of the season you will need to loosten the spring bolts and spin the clutch plates. If you don't do that the plates will rust together and you won't have protection for your PTO.
If you have an electric PTO, throttle down to just above an idle, before starting and stopping the PTO, you will reduce the load on your PTO clutch and brake.
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
44052 (A55852)
44052 (A55852)
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
