sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,744
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Have a couple of small fields that have been compacted (20 years, horses running on them) also have been fighting a Knapp weed infestation. Bought a well used 6' disc, and JD pull type 3 bottom plow, going to try and plow and disc, New to (field prep and planting) want to plant field grass. Ok today hooked up the plow and discovered one of the hydraulic lines was to short when turning the tractor, picked up a drawbar for the disc (didn't come with one) and a short piece of hydraulic line and female swivel, got the hose lengthened, works good no leaks, Headed out to the field made 4 counterclockwise laps (that's the direction) the previous owner said plowing is done, sometimes furrows looked ok some ended up looking like a sod truck had overturned- and so it begins...got to dark- so tomorrow will try again, will try to post pictures of progress.
