stick work clamp
/ stick work clamp #1
daugen
Epic Contributor
New Hope PA
in between now
Could someone explain please a few do's and don't's for using the ground/work clamp?
Should the work be insulated from the earth below? How about when using a metal work table?
I bought a strong magnet gizmo that locks onto plate steel, which says it works as a place to attach the
work clamp. I will be doing mostly repairs and fab using flat steel, nothing round at this point.
If one was adventurous enough to touch the work with a bare hand/finger while welding, would you get shocked?
Trying to understand where the hazards are here, and minimize them.
I haven't even turned on my new welder, it's sitting patiently waiting for me, but thought this was a topic
I should get well educated on before I get started.
thanks Drew
/ stick work clamp #2
Do clamp as close to your weld as possible.
Do not clamp in a location that puts a bearing, bushing, or electrical gear between the clamp and the weld.
Do clamp to bare metal - grind some paint or rust away if you have to.
Do not assume that clamped or bolted joints are good electrical conductors.
If you were so adventurous as to touch the work with bare hands while welding, you would be shocked at how incredibly hot, painful and rank smelling your burning flesh is, but you would not receive an electrical shock. I'd just add that I would never grab the stinger in one hand and the ground in the other - you never want to put your heart in the circuit.
/ stick work clamp
But I always put my heart into things...:eek:
Ok, keep thinking of a very powerful electrical circuit that one wants to control, not get
in its path. Like lightning in your hand... Or perhaps more plainly, like having the main AC supply
to my house in my hand, 160 amps isn't far away from 200 amps, so there's a whole lot of
juice in that stinger, which needs to stay far away from the ground clamp. Remember, I've never done this before,
and sure have not walked around with 160 amps in my hand. That I don't want to find a way to my heart.
Even if I put my heart into it...:thumbsup:
/ stick work clamp #4
Drew, keep in mind when that arc is drawing 160 amps the arc voltage is about 20 volts or so... Now the open circuit voltage will be a lot higher. by law it cannot be above 80 volts, but even if it its less, lets say 60, it is still enough to kill you if your wet and you are silly enough to grab the work clamp and the stinger in each hand. So don't "put your heart in it" so to speak. Don't become "part of the circuit", but touching one polarity or phase will not shock you, as long as you don't touch the other polarity (if DC) or phase (if AC). But you are far more likely to be burned than shocked. Keep your gloves on, and even when you think the steel is cool, you might be surprised how hot it will remain for a time. You don't need to be a "scare'dy cat" and afraid all the time, but you don't need to be a fool either. Use proper caution and think things through. Now get out there and strike that first arc, and conquer your fears and anxiety's and start making sparks and melting metal:thumbsup:
James K0UA
/ stick work clamp #5
I have welded in very wet conditions and with wet gloves, wet boots and soaked to the skin and got my share of tingles from the welding leads. When you are wet, grounded and have wet gloves, the electrode holder can give you a little tingle without touching the ground. Grabbing the bare ground clamp while holding on to a wet rod will give a pretty good jolt if your gloves are wet. Keep dry and you will not have a problem. DC current is less likely to shock you than AC as it requires a better ground but it will nab you at times. Generally it is nothing to be afraid of just a slight tingle when it bites you, but do take precautions as folks have said.
/ stick work clamp #6
if you must work in wet conditions, slip on a pair of dish washing latex gloves first ... then the welding gloves ...
/ stick work clamp #7
All well and good, but if you should be so unlucky as to burn yourself, that latex is going to make a mess of you.
Daugen: as James points out, your house is 200 amps at 240 volts. Your welder operates at much lower voltage. It can push 160 amps through clean metal, which is very conductive, but through a person there will be much less current flow, because of the higher resistance of the human body. Even paint or mill scale will stop the arc from striking.
/ stick work clamp
Ok, I won't be a wuss with the juice, it's what makes welding work. I just have a healthy respect for anything that will truly light up my life.
I bought a pair of good Miller welding gloves and once the machine gets turned on, I will try to think twice before moving once.
And burns really, really hurt...
But then so would my chainsaw if I whacked my leg with it. And I love my chainsaw...
Just have to be careful, focused on the job and have gone through a short mental safety check list first
My conclusions so far are that it's unlikely I'm going to shock myself, because I just won't weld in damp conditions.
But I can burn myself, but that's what proper clothes are for.
there are lots of adjustments on the helmet I bought, but I can't do much with that until I'm actually welding and
have something to look at while I adjust the helmet controls.
Lot of totally new stuff to learn here but so far seems to be mostly common sense.
And I've been mentally practicing getting in the zone and slowly dragging that rod. It's the little squiggles I see in so many welds that
still puzzle me, some seem functional I suppose and some even decorative. Like frosting a cake when you really know what you are doing.
No frosting for me, I'd like to get to a continuous functional weld that isn't full of spatter. I'll leave the squiggles until later...
And yes, I will show you my first weld. ArcShield, start drinking now...
/ stick work clamp #9
This old video will help show you how the "little ripples" are formed by the arc force pushing up the bead.. You will have a better understanding after viewing.
How Arc Welding Works - YouTube
James K0UA
/ stick work clamp
Jim, I've seen lots of videos where it looks like the welder is using a gentle rotational or even back and forth motion, sort of like stirring the pot...
and I wondered if that individualized attention would have an effect on "the ripples".
I enjoyed the video, it's a good basic one.
thanks Drew
/ stick work clamp #11
Everything you do has an effect, and some rods are "fast freeze" and make rougher looking ripples in the bead. and 7014 will usually make a smoother bead.
/ stick work clamp #13
Don't forget that to get zapped you would need to contact both the stinger/electrode lead and the work/work lead at the same time. And the stinger is well insulated(no exposed metal), so touching the work is no big deal.
/ stick work clamp #14
This isn't true. I got zapped once when I touched the work piece with a bare hand and put a knee down on the wet ground. It was a very mild tingle--not even a "zap" per se--but I got it. I don't know whether this is normal, or if it's indicative of a fault in my welder, though. But even taking the work clamp out of the equation, can't you get current flow between the stinger and ground? Stand in bare feet on wet ground and grab the electrode with your bare hand and tell me what happens.
/ stick work clamp #15
bad welder. The insulation on the windings has broken down. Likly from being over heated.
With power off, check the resistance between the output leads, and the plug leads. Should be very high resistance. If not you can have the input voltage at the output leads. Very dangerous.
/ stick work clamp #16
If you weld you will get bit, it happens. I got bit hard splicing a beam laying on a concrete floor. I was dry, gloves dry it happens. You asked about a magnet, I had s buddy that used one. 4" sq in a box that had a spring holding down pressure on a claw hammer. Ground was bolted on the head, claw contacted the work. It sounds crappy but it worked very well. Beat a grasshopper, because it stayed put.
/ stick work clamp #17
The table can be grounded. Placement of the work clamp should always be fairly close to the work if possible (though a thousand times a day, it is not being done that way). The biggest shocker is getting sweaty and touching something while working. Generally speaking, you won't get shocked. The biggest chance of getting shocked is when you are changing electrodes and your gloves are sweaty and you are well "grounded" either against the work piece or the ground itself. You'll get a tingle for sure. In this case, you can sort of "throw" your rod in with the clamp style holder and never have to make electrical contact. Someone said that law prevented it from being over 80 volts. Not sure about that since there are several companies with 90 OCV units. The famous SA 200 had an ocv of 90 V. The new maxstar 150s has an ocv of 90.
/ stick work clamp #18
Underwriters Laboratory is less than 80 OCV for welders to be eligible for UL sticker. I believe many welders can and do have more OCV but they are typically industrial units or lack UL seal of approval if homeowner grade.
P.S. Sorry for incomplete response first time around - totally struggling with smart phone keyboard. Finally switched to laptop to get everything typed correctly.
/ stick work clamp #19
Industrial units have Ul listing too, and I doubt Miller would skip that on the maxstar baby units.
/ stick work clamp #20
I found this on an OSHA website.. looks like DC units and Automated units can be 100 volts. but apparently AC units 80 volts.
..1910.254(b)(3)(i)(A)
Manual arc welding and cutting - 80 volts.
1910.254(b)(3)(i)(B)
Automatic (machine or mechanized) arc welding and cutting - 100 volts.
1910.254(b)(3)(ii)
Direct-current machines
1910.254(b)(3)(ii)(A)
Manual arc welding and cutting - 100 volts.
1910.254(b)(3)(ii)(B)
1910.254(b)(3)(iii)
When special welding and cutting processes require values of open circuit voltages higher than the above, means shall be provided to prevent the operator from making accidental contact with the high voltage by adequate insulation or other means.
1910.254(b)(3)(iv)
For a.c. welding under wet conditions or warm surroundings where perspiration is a factor, the use of reliable automatic controls for reducing no load voltage is recommended to reduce the shock hazard.
kobota mx5400 for sale
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2014 JOHN DEERE 50G EXCAVATOR (A65056)
2014 JOHN DEERE...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
3 PALLETS OF WHEEL/TIRES (A68842)
3 PALLETS OF...
