Running a log spitter off of my power beyond hydraulics for a BX25
   / Running a log spitter off of my power beyond hydraulics for a BX25 #1
bx25d
Red Wing, MN
BX2360
So I'm looking at buying a Wallenstein WX310 3ph log splitter for my Kubota BX25. I want to run the splitter off of the power beyond hoses that are used for the backhoe. I don't know a lot about hydraulics but my concern is the splitters specs recommend a minimum of 10 GPM of flow to the splitter. The specs on my bx25 say that I have 6.2 GPM of flow. Will the splitter work with that flow? Also, what's the PSI's rated at for the bx25? My guess is that it will work and I will still have enough power to get through big logs but the speed with drastically drop. Would I be correct in assuming that? Any help would be great!
   / Running a log spitter off of my power beyond hydraulics for a BX25 #2
You are right.... GPM flow rate determines speed. Your full stroke cycle time will be close to 1/2 a min... but you should have plenty of power, Just will take longer.
   / Running a log spitter off of my power beyond hydraulics for a BX25 #3
It will be slower then that because the BX has a priority valve that takes a portion of the flow for the power steering circuit. This is why at near idle you have no hydraulic flow for the loader.
David Kb7uns
   / Running a log spitter off of my power beyond hydraulics for a BX25 #4
1850 psi at WOT for "kubota recommended pressure". I am not sure if you can get thru the big stuff though. You will have to ask al yelvington. He the one who documented the 3 pt splitter to work with his BX .
   / Running a log spitter off of my power beyond hydraulics for a BX25 #5
If using 6 GPM for the flow, here is the data for the cyl power and speed.
I guess one way to get around the problem is to just have a pto pump with hydro tank but that kinda defeats the purpose of what I'm trying to accomplish- especially when i have a 23hp diesel at my disposal and i cant even utilize it for a simple log splitter! Is there no other way other than a pto pump?!
Thanks for that data J J
   / Running a log spitter off of my power beyond hydraulics for a BX25 #7
You have about 1.8GPM going to the priority valve for steering, PTO clutch and Hydro charge.
So you will have around 4 GPM left for splitter. I have a Speeco 34 ton stand alone splitter with a 15 second cycle time or you may use a PTO pump for quicker cycle time.
When I am splitting large blocks I use the BX to move them.
David Kb7uns
   / Running a log spitter off of my power beyond hydraulics for a BX25 #8
I ran one on my BX22 it had about a 15 second cycle, which was fine for me. Worked well and I much rather have one less motor to maintain
   / Running a log spitter off of my power beyond hydraulics for a BX25 #9
Time for the 99.oo Harbor freight 6.5 horizontal gas engine. Then the pump,valve, and tank. You quickly see why splitting wood gets expensive.
   / Running a log spitter off of my power beyond hydraulics for a BX25 #10
Have you looked at the splitfire log splitters? I have a 3203 3 point model and love it. With splitting both ways it makes up for the lower gpm. The wallenstein looks like a good splitter too except for only splitting one direction.
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
