X740 5HR review/18 Steel cart and compatible info.
/ X740 5HR review/18 Steel cart and compatible info. #1
JDTank
Well, I have just shy of 5 hours on my X740 now. I love the machine, there really is no other way to say it.
The few gripes I have are minor, but annoying ones. I recently picked up a front brush guard, and a #18 steel cart. First of all, you cannot remove the mower deck, without first removing the brush guard. I find this an annoyance and borderline lazy engineering. The next item, my tractor has the receiver hitch kit on it. With this kit, the hitch on utility trailers actually wedges itself into the receiver hitch kit when turning. I have included a picture for people to see what I mean.
Fuel consumption. I personally find it just a hair high right now, but, this engine is nowhere near broken in. Right now I am using about 2.5 - 3.0 Liters per hour, depending on how hard I am working the machine.
2 Wheel Drive. I am actually VERY impressed with the traction this machine has even for being a 2WD unit. I do notice however, that since the front wheels turn so sharp, if your on slippery ground, the tractor has a tendency to push forward slightly, even with the tires turned. I FINALLY managed to get the machine to slip today. I was on VERY slick wet muddy ground pulling a heavy load of wet dirt/moss. One tire slipped only for a few seconds, but it didn't slow down any. I still do not regret passing up on the X748, I saved $1,800 by doing so.
The ride. Extremely comfortable. Even the basic factory seat is very comfortable and padded. With the proper tire pressure, I do believe this machine is the Cadillac of garden tractors. I love sitting up high and having a commanding view over a big square hood.
#18 steel cart. I am very pleased with the cart, but not as impressed as I had hoped to be. The dump angle is actually quite tame. I found with the tailgate attached, it was stopping my leaves/moss from exiting the trailer. If I removed the tailgate completely, everything dumped without an issue. The latch that holds the cart body down while in use is somewhat primitive in my opinion. For a $400 cart, I would have liked to see a better system for releasing and locking the body. Assembly is a PITA, especially if you are by yourself. It is easy to assemble, but tedious at points. I also strongly dislike using a half inch pin to connect the trailer to the tractor. It allows a lot of slack, and as you are going over uneven terrain, you feel the cart constantly moving in and out, banging against the tractor hitch. I will be cutting the nose off of the cart frame this week and bolting on my own ball hitch mount. This way I can use the trailer with my receiver hitch, which will eliminate the clearance issue with the factory design, and it will eliminate all of the slack as well.
I purchased the brush guard today by fluke actually. I had wanted one since I purchased the machine, but my dealer had none in stock, and I didn't bother to order one, as money was tight. Well, I phoned them on Thursday afternoon, asking the parts man if they had any in yet. He laughed and told me he JUST came inside from removing one off of a brand new X728 they just sold, believe it or not, the customer did NOT want the brush guard! I asked him if it was "heavily discounted" since it was used, and he said I will see what I can do. The normal selling price at my dealer is $282, he gave it to me for $180, already assembled, brand new! I couldn't passed that up so I jumped on it. I really think the brush guard completes the look of this machine. I always felt like something was missing before I had one.
Overall, I can't think of a better machine in existence if you have some serious yard work to do. I used to dread any type of yard work because I was using my in-laws cheap, ill maintained equipment. Now that I can finally afford my own, I look forward to every minute in that yellow seat. I take extremely good care of my things, and I know this machine will last me a lifetime.
/ X740 5HR review/18 Steel cart and compatible info. #2
No doubt a new John deere is hard to beat, and theses x700's are really nice looking as the pictures you took show it very well. Enjoy your new Deere they are a really, really nice tractor.
Rob
/ X740 5HR review/18 Steel cart and compatible info. #3
hi JD
i think you will find that there will be a lot of slop in the drawbar with the receiver kit as well. if you figure out how to tighten it up, let me know. i use a couple different drawbar drops to keep whatever i connect fairly level. both of them bang around when driving over uneven ground.
after you cut off the front of the tongue and bolt on a ball hitch, paint it yellow or green :)
/ X740 5HR review/18 Steel cart and compatible info. #4
What does a tractor like that go for?
A LOT.
By the time it was all said and done, I paid just over 10K. I don't regret it at all. Yes it's a lot of money, but now I enjoy yard work, which has to be done whether you like it or not.
We spend our entire lives working just to survive. If I only get to live once, and I have to spend that life working, to make another man wealthy, than your **** straight I will be happy at home!
/ X740 5HR review/18 Steel cart and compatible info. #6
That lip around the bottom of the cart at the rear has a tendency to get hung up on stuff or will pile up dirt sometimes while dumping and pulling ahead. If that happens to you find a way to slope it some. I used to have a similar cart
/ X740 5HR review/18 Steel cart and compatible info. #7
A LOT.
Whoa! I was just asking not laughing at you. Did you look at Simplicity or just go green?
/ X740 5HR review/18 Steel cart and compatible info. #8
A LOT.
I hear ya...My X748SE was around 15K fully decked out with 3pnt, rear and front PTO and all other goodies. I never regretted it.
John Deere must have updated this. When did you buy your cart?
Underneath the bottom lip of my cart at the back, is a rolled, angled piece of steel, welded onto the underside. When the back of the cart drags on the ground, it simply goes over everything, doesn't dig into the ground at all.
LOL, you have to be joking.
Simplicity machines are absolutely, without a doubt, 150% god awful looking. Looking at those machines makes me want to puke.
The John Deere is a superior product, I believe, and not only that, it's a very sexy looking machine too. There is no better garden tractor on the market, than the X700 series.
/ X740 5HR review/18 Steel cart and compatible info. #11
My Simplicity will out cut your JD any day. I was not insulting you so you have no right insulting me so be nice. LOL my machine ran 5400.00
I wasn't insulting you, but you keep believing whatever you want to.
As far as the tractor itself goes, John Deere IS the superior machine, that isn't even worth arguing over. Simplicity has some pretty wacky ideas, like putting springs on the rear axle of a machine. Tractors need solid mounted axles to be durable and take abuse, not springs and coil-overs that can break under stress.
I haven't seen a mower deck that can cut better than a 7-Iron deck. I would say anyone with a 7-Iron deck can at least match, if not beat your simplicity.
You get what you pay for. My tractor will be worth $5,400 in 10 years with 1,000 hours on it, and you paid that just to get yours.
/ X740 5HR review/18 Steel cart and compatible info. #13
I looked at the simplicity legacy XL model with diesel motor not a bad tractor but it had a 12 ga. deck compared to the 7ga. iron deck and the yanmar diesel were the difference in why I bought the JD X740.I wanted to add I bought a simplicity/ferris mower zero turn mower the heavy duty model 25 hp kohler engine 61 inch cut with there independent suspension and have to say that was the best mower for ease on your back and body.I thought there suspension was a gimmick until I bought my Kubota 326 pro (diesel) ZTR and I am here to tell ya it beat the H$LL out of my back compared to the simplicity ZTR.coobie
/ X740 5HR review/18 Steel cart and compatible info. #14
Heep big thick head, No springs on my tractor where the **** you get that from? I have over 175 hours on mine and it has NEVER broke down. Your deck will not do stipping
/ X740 5HR review/18 Steel cart and compatible info. #15
All the guy did was ask what you paid and then asked if you looked at simplicity. Or am I missing something
The JD decks will stripe actually, it's an optional add-on kit.
Look on simplicity's website, it's their latest selling gimmick, "automotive style suspension"
I would hope it hasn't given you any trouble at 175 hours, because that's nothing.
In short, no, I didn't look at simplicity. I find them extremely ugly, and cheap. It looks like a cheaply made small import vehicle. As coobie pointed out, your mower deck is a thin 12 gauge steel. John Deere uses 7 and 9 gauge. Simplicity has a 3 year warranty on the Legacy XL, John Deere has 4 years on the X700 series. John Deere offers a diesel engine in 2WD, simplicity does not. John Deere uses a vastly superior Yanmar diesel engine in it's diesel X7 units. Simplicity uses a briggs & stratton diesel in it's Legacy XL. There is no comparison between the 2 engines, the Yanmar takes the cake.
/ X740 5HR review/18 Steel cart and compatible info. #17
Yea but yours cost twice as much, Good luck with your machine. My 3 way hitch is much cooler than yours that does not even work right. That auto style spring suspension is on the zero turn which is made by Ferris.
What are you, 5 years old? Cooler than yours? Seriously, try to find some maturity.
Take your stupidity, and your fan-boy simplicity love and leave my thread.
This is the John Deere section, for John Deere owners.
/ X740 5HR review/18 Steel cart and compatible info. #19
At least my hitch works! see ya!
/ X740 5HR review/18 Steel cart and compatible info. #20
JD tank,I want to tell ya I had my rear tires loaded with rimguard and it really helps with traction if you want to go that route.coobie
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2016 Ram ProMaster 1500 (A60462)
2016 Ram ProMaster...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
2011 International Prostar Premium (A60462)
2011 International...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
