Missing bolt??
/ Missing bolt?? #1
RosseauK
Member
KiotiDK40se
As I was cleaning some snow off my tractor this week I noticed one of the bolts that hold the cylinder and zerk in place was missing. Had to snowmobile to my tractor and didn't have a wrench to take another off for size comparison. Does anyone know the size and length of these??
/ Missing bolt?? #2
Assuming you have a KL401, the parts site (OEM Parts ) says:
6 01133-51016 Hex Head Cap Screw, 10mm x 16mm $2.03
7 04613-50240 Stop Ring, E Type $1.00
/ Missing bolt?? #3
I have lost 3-4 of these over the past few years...for some reason even with lock washers they fall out. Now i just keep occasionally checking them when greasing. I ended up picking up 8 of them at Fasteners Inc. there the 10mm fine thread style . 16mm as stated above. grade 8.8
at Fasteners there less than 0.25 each.
/ Missing bolt??
Cool thanks for the help guys!!
/ Missing bolt?? #5
I check them about every other time I grease, or 20 hours. I havent lost any, but one was nearly half way out once.
James K0UA
/ Missing bolt?? #6
If these work lose, you may have play between the pin and the hole (in the piece it's bolted to) that allows movement. Or maybe you just use your loader more than me.
/ Missing bolt?? #7
Are there nuts too?
Do you use lock nuts?
What about using thread lock? The strongest (red?)
Do you have access to both sides of the bolt? You could also peen the end, or add two lock nuts.
I got it.
instead of such bright and shiny bolts, you just need a little RUST :thumbsup:
/ Missing bolt?? #8
Are there nuts too?
I got it.
there is no nut. it threads into steel . thread locker probably isnt a bad idea. there is a lock nut
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2015 Volvo L110H Articulated Wheel Loader (A64553)
2015 Volvo L110H...
VERMEER FT 100 FORESTRY MULCHER (A65053)
VERMEER FT 100...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2020 TAKEUCHI TB240 EXCAVATOR (A65053)
2020 TAKEUCHI...
