Engine trouble
/ Engine trouble #1
Griffin1708
Birmingham, Al.
Thomas 133
Kubota engine does not smoke at cranking and very hard or does not start
Fuel in filter and to injector pump
/ Engine trouble #2
Hey Griff, that may take just a wee bit more explaining.
Welcome aboard, though. :thumbsup:
/ Engine trouble #4
:welcome: to TBN
/ Engine trouble #5
Did this start all at once or come about gradually? Tractor model ,size engine,does it turn over rapidly, Number of hours on machine?You will find alot of knowledge on this site, but more clues are needed.
/ Engine trouble #10
Id say check air filter. We need more info.
Welcome to the forum.
/ Engine trouble #11
There is a big Kubota presence here. With a bit more information , I'm sure they can help you. -kid
/ Engine trouble #14
Welcome to TBN:thumbsup:
/ Engine trouble #16
welcome ..................
/ Engine trouble #17
You want to check for power to the shut down solenoid, If you are not getting smoke you are not getting fuel. I am not a Kubota expert, but you need fuel flow in the pump. As stated if it has Glow plugs check them also.
An engine has to have good air flow,an appropriate cranking speed, and fuel, at an appropriate time and flow.
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
FRONTIER HYD BALE SQUEEZE (A64277)
FRONTIER HYD BALE...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
Copper Eagle Weathervane (A65583)
Copper Eagle...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
