54'' deck on X700 series.
/ 54'' deck on X700 series.
I purchased my X700 in September 2012, and I am very pleased with the performance. I ordered it with a 48" deck which cuts better than my old TroyBilt Wide Cut. I selected the 48" deck due to the steep road bed that I can side hill cut, and because the deck is only a couple of inches wider than the tractor I can climb on or off the the slope without the ends of the deck digging into the lawn. I am running JD mulching cutters along with the mulching kit. Trimming around the flower beds is not an issue... YES I am very happy with the set-up!
The only other downside to the 48'' deck besides it's small width is that you cannot use front fenders on the x700 series with a 48'' deck. For some people they don't care, but I can say now after taking delivery of my tractor without them, and then installing them 2 weeks later, I won't ever go without them again.
/ 54'' deck on X700 series. #42
I agree, keeping grass at least 3" long gives you all the benefits Gittyup mentioned. I wish my lawn would grow as fast as the OP's. I can't get mine to grow fast enough. There is nothing more relaxing to me than cutting a nice thick lawn on a sunny day.
In the summer I will cut my grass in the evening where I can finish cutting it just before it gets dark. Takes me about 1 1/2 hour to cut everything. I have three sections to mow so I start the watering as soon as I finish the first section this takes about 10 hours to run through all the zones. Mowing in the evenings is less stressful on the grass from everything I have read.
/ 54'' deck on X700 series. #43
Hmmm interesting, I really never thought about the time of day you mow being more or less stressful on the lawn. Makes sense I guess.
10 hours of watering, you either have a large lawn or you do some deep watering. I do 45 minutes per zone, times 9 zones comes to just under 7 hours. I don't know what your area charges for water, but doing that every other day around here brings my water bill to over a grand a year.
Jenkins if I remember right, you recently wrote a post about top dressing a lawn. I don't remember if you were making an implement or buying one to do it. I need to do it to my lawn this year and was thinking about using this manure spreader. What do you think?
Newer Spreader
/ 54'' deck on X700 series. #44
Newer Spreader
Wow, and I wait until late afternoon to mow my lawn so I don't dirty the mm deck or the tractor!
/ 54'' deck on X700 series. #45
Newer Spreader
Carl,
I don't have much faith in this unit doing a good job, I suspect a better manure spreader would yield much more satisfactory results. Metering out the compost isn't that simple.
/ 54'' deck on X700 series. #46
Carl,
Yeah I was afraid you were going to say that. I'm glad I held off. Even when I spoke to the salesman, he didn't seem absolutely sure that it would work. He was more like "yeah it should work ok with top soil", not very reassuring. I wouldn't mind spending the extra bucks on an actual Top Dresser, but they are just too big for me to store.
I guess I'll have to just dump and spread the top soil with my plow or maybe a York rake. My only concern is, I want to apply it thin enough that the existing grass can still grow through it. Thanks
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2005 STERLING L9500 MIXER TRUCK (INOPERABLE) (A63569)
2005 STERLING...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DEUTZ ENGINE (A63569)
