case 580d cylinder question
/ case 580d cylinder question #1
chrisdvorak
Gold Member
RI
too many
On my case 580D some of the cylinders have a small screw in the end cap of them, what does this screw do? I thought it may be there to keep the end cap from loosening but not all the cylinders have it.
/ case 580d cylinder question #2
Don't remember if all the cyl's on my 580B have them, but that's what they're for - in my experience, the little hole will NOT line up after you re-seal your cylinders. Not sure why.
Are yours leaking, or just curiosity? Steve
well, both they are leaking a bit but I'm rebuilding the stabilizer cyl now and it doesn't have a screw in it so I wanted to know if there was a different way to rebuild or bleed the other cylinders.
/ case 580d cylinder question #4
Only thing I can think of someone used screw to lock gland in place bleeding is done by opening and closing control valve from the cylinder to the tank from the return line. To get the cylinder cap off use a spaner wrench. I use hot water to aid gland seal installation.If the rod has crome damage the new seal wont last long.
/ case 580d cylinder question #5
My 680h has both screw on some cylinders and some of them just have a plastic thread lock on the inside . The plastic fits in a hole in the gland and squishes into the threads as it is being tightened. Hope I explained it to your understanding. But both are there to lock the gland in place
/ case 580d cylinder question #7
.................. But both are there to lock the gland in place
After repack, you can redrill if they don't line up again or just reuse the old holes
/ case 580d cylinder question #8
How about a heat gun on those gland seal, I think I just ruined one last weekend.
Rancher
No, don't use heat gun..!!
Hot water only (boil it without the seal in the microwave, then add seal after it comes out)
If you have a clean pair of needle nose pliers to donate, you can make a good tool to help install the seal (long slender is best)..........use a grinder and a sander to remove the sharp edges on the two jaws all the way up to the hinge.....round it out, smooth and poilshed, no sharp edges
when installing the seal, put one side in the groove (hold in place with finger), then use the custom pliers to grab the opposite side that is still outside the groove, then twist the pliers 180 degrees (while the other side of seal is still in the groove)
With a little practice you'll realize there is no need to warm the seal, it'll go in two seconds, one shot.......DONE.....:cool2:
/ case 580d cylinder question #9
Do you have a picture of your special tool?
I only have trouble on the small cylinders... 2" size, I got it 75% in the groove and used a blunt screwdrive to pop it in. I don't think that was my problem, it was when I was re-installed the rod, I think it had a sharp edge and ripped the gland.
Rancher
/ case 580d cylinder question #10
Kivel trailer mover attachment (A61567)
Kivel trailer...
2005 KENWORTH T800 OPEN ROLL OFF (A60736)
2005 KENWORTH T800...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2019 GALYEAN...
2018 FORD F-150 (A60736)
2018 FORD F-150...
