The kid
Elite Member
- Joined
- Apr 25, 2012
- Messages
- 4,113
- Location
- Middle Tennessee
- Tractor
- 1965 135 gasser, 1967 135 diesel
Well this one is recessed over an inch deep.
I can take the rear bolt out and move the hydraulic assembly, the bolt is free on the threads, it is rusted around the head inside the recessed hole. I filled it with penetrating oil and left it hoping it will free it up a little. But the only solution I really see is drilling it out. I really need about a 3/8" left hand drill bit, so hopefully it won't drill it all the way out before it gets it loose and backs it out.
Well it looks like Murphy's Law has stricken again. Since your dealing with a rusty shaft. Question: Is there threads all the way thru the head body. If not, and by the way your describing the body moving. I would put the other bolt back in (for alignment) not fully tight and start using leverage to force the body upwards till it broke the rust free. Once you have freed the valve assembly a bit of heat on the evil broken bolt should do it with a pair of vise grips. Last resort you could drill the bolt and use an "easy out". What you have described and what has occured I think and "easy out" would be fruitless . After all the bolt did shear. I don't think putting a modest amout of pressure on the valve body will damage it,, but might break the rust free. -kid
