'73 MF135 Perkins diesel AD3.152 help
   / '73 MF135 Perkins diesel AD3.152 help #101
Wells VR715 or import replacement.
Here is a pic of mine. It provides solid state voltage regulation to the externally regulated alternators without any wiring changes. Modern regulator, no contacts, no over/under charging, no wiring changes.
   / '73 MF135 Perkins diesel AD3.152 help #102
Some tractors had an alternator with an external regulator. Delco 10DN. Mine was born with this configuration and I simply replaced the external regulator with a solid state version that looks the same and plugs right in. It was less than $25.
It regulates like a modern alternator with solid state internal regulation but looks stock.
That 10DN alternator will set you back anywhere from $85 to $150 if you ever have to replace it. The Delco 10SI which doesn't require external regulation can be found working used at a junk yard for $10 or new for less that $50. Either way would work. One way is cheaper though. A 10DN would probably have to be ordered. Not very common just as the Genny. The SS VR is around $20 +shipping.
   / '73 MF135 Perkins diesel AD3.152 help #103
Sure, but I had a 10DN and didn't like the crappy regulation. For $25 my problem was solved and my tractor looks like the way it did the day it rolled off the line without a mangled wiring harness like most 'restorations'.
   / '73 MF135 Perkins diesel AD3.152 help #104
I'm not saying it's not as good. I mentioned the cost difference if your alternator fails you could then switch over. As I mentioned to lug nut. A lot of folks will leave the existing VR to maintain an original look and use it as a tie point. I started to, but mine looked pretty rough and didn't want to put the effort into restoring the looks of something that was replaced. It's good to know that there is a solid state version out there at a reasonable price.
Haven't done much with my tractor lately. But I did just leave the dealership, I ordered the hydraulic cover so I can take off this auxiliary hydraulic junk.
Well, I picked up my cover from the dealer yesterday, thought it would be a simple replacement. And it would've been if one of the two allen bolt heads didn't strip out... I guess after almost 40 years it's gotten a little rusted and stuck. I guess I'll get some new bolts and drill this one out.
   / '73 MF135 Perkins diesel AD3.152 help #107
Rust is a common problem on these old tractors, and I've had more than a few stuck and/or broken bolts to contend with myself. Before drilling it out you might want to consider welding a nut onto it and using a wrench for removal.
Well this one is recessed over an inch deep.
I can take the rear bolt out and move the hydraulic assembly, the bolt is free on the threads, it is rusted around the head inside the recessed hole. I filled it with penetrating oil and left it hoping it will free it up a little. But the only solution I really see is drilling it out. I really need about a 3/8" left hand drill bit, so hopefully it won't drill it all the way out before it gets it loose and backs it out.
   / '73 MF135 Perkins diesel AD3.152 help #109
That changes everything, and I agree that welding a nut to it under those circumstances would be impossible.
Have you considered using an easy out, also called screw/bolt extractors? Avoid the cheap junk and use a good set like those made by Irwin for the best results. Another thing I've found that sometimes helps, is to take a piece of rod and lightly hammer the top of the stuck bolt prior to removal, the shock helps to dislodge the rust.
I tapped on it quite a bit with the 5/16" standard allen wrench I was using with no help. I was going to try an EZ out but I couldn't find the right one at my house. And instead of buying an EZ out I'd rather just buy a left hand drill bit and be assured to get it out one way or the other. I even took a very thin punch and tapped tiny holes around the edge of the bolt to try to help the penetrating fluid to seep in and break up the rust. I am using Kroil oil so if anything will get it done that will.
2007 International 4300 Dump Truck (A51692)
2007 International...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2018 VOLVO EC480EL EXCAVATOR (A52707)
2018 VOLVO EC480EL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
