B3200 dual speed PTO
/ B3200 dual speed PTO #1
kuboman
Canada
B3200, L5740,
So the other night I was cruising the parts book like I often do for entertainment and I came across a 2 speed rear pto option. Does anyone have it on their B3200 or know if it can be added after.?:confused:
I have not seen anywhere in Kubota literature about it.
/ B3200 dual speed PTO #2
Just ran across this thread. I'm curious about this too. I've got a snowblower on my 3 point - that just doesn't want to throw the snow (an older Loftness blower).
If I remember correctly - the blower originally was setup to work with some sort of mower - which had a 2500 rpm PTO - this was reduced thru a gearbox to feed the blower - and the gear box is a 4 to 1 reduction - which would put the blower right in the 720 range for proper function.
Which parts book did you see the 2 speed PTO option in?
I have a friend with an older B7500 - and he says his has a dual speed rear PTO
I found it in the online parts book. Looking at it though it looks like the tractor needs to be slit but I might be wrong. Another gear needs to be added but not sure if that can be done from the back through the pto unit or not.
/ B3200 dual speed PTO #4
a dual speed pto is 540rpm/1000rpm
/ B3200 dual speed PTO #6
Did you ever find out any more information about this? Just curious as it sounded like an interesting upgrade.
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
PT 8' x 12' 2 Axle Wagon (A64911)
PT 8' x 12' 2 Axle...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
HERRING 500 BBL FRAC TANK (A68842)
HERRING 500 BBL...
