B3200 dual speed PTO
/ B3200 dual speed PTO #1
kuboman
Canada
B3200, L5740,
So the other night I was cruising the parts book like I often do for entertainment and I came across a 2 speed rear pto option. Does anyone have it on their B3200 or know if it can be added after.?:confused:
I have not seen anywhere in Kubota literature about it.
/ B3200 dual speed PTO #2
Just ran across this thread. I'm curious about this too. I've got a snowblower on my 3 point - that just doesn't want to throw the snow (an older Loftness blower).
If I remember correctly - the blower originally was setup to work with some sort of mower - which had a 2500 rpm PTO - this was reduced thru a gearbox to feed the blower - and the gear box is a 4 to 1 reduction - which would put the blower right in the 720 range for proper function.
Which parts book did you see the 2 speed PTO option in?
I have a friend with an older B7500 - and he says his has a dual speed rear PTO
I found it in the online parts book. Looking at it though it looks like the tractor needs to be slit but I might be wrong. Another gear needs to be added but not sure if that can be done from the back through the pto unit or not.
/ B3200 dual speed PTO #4
a dual speed pto is 540rpm/1000rpm
/ B3200 dual speed PTO #6
Did you ever find out any more information about this? Just curious as it sounded like an interesting upgrade.
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
2022 FORD F-250 XL SUPER DUTY CAB & CHASSIS (A67714)
2022 FORD F-250 XL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2014 Jeep Cherokee Limited SUV (A66738)
2014 Jeep Cherokee...
PORTA POTTY (A67714)
2011 WESTERN STAR 4900SA (INOPERABLE) (A67714)
2011 WESTERN STAR...
