Show What Tool You Made*
/ Show What Tool You Made*
Here's another tool photo I just dug out. It's a pipe notcher I built.
Just make another and send it to me. FedEx overnight.
Seriously, that thing is great.
/ Show What Tool You Made* #22
Wow .. That reloading press is great !
Here's my oil change tool. A socket extension to reach the drain plug on a low slung car without lifting it. Made with 1/2 pipe welded between an extension cut into two pieces.
I see you bolted it to the floor. I was wondering how you were going to stabilize it. Great job.
I made 2 pedestals using old JD flywheels as bases. I did not want to ruin the flywheels with welds, so I bolted the pedestals to the flywheels. They are really heavy and very stable, but probably not for a vise.
GrinderPedistal1.jpg GrinderPedistal2.jpg CLICK TO ENLARGE
The hose roller is made to either mount on this pedestal or quickly mount it on the wall of a race car's support truck.
/ Show What Tool You Made* #24
Thanks murph. I guess it will take a while for anyone to post anything else, but just to generate some interest in this thread, I will show this 12 volt electro magnet I made about 20 years ago to magnaflux engine heads for cracks. I got the laminated steel plates at a salvage yard. I think they were from a microwave oven transformer. I got the insulated wire from a motor rewind shop, along with some useful information on how to make it. I had to make a special tool to turn the laminate so I could wind the wire on evenly and not harm the wire's insulation (it's like a coating of varnish or paint). After I finished it, I took it back to the motor shop and they dipped it in that insulation for protection.
The magnet is so strong that 2 people cannot pull it off a sheet of steel. In the photos, I put a drink can for size comparison. That loop on top is just a rope handle to carry it.
View attachment 306353 View attachment 306354
View attachment 306355 View attachment 306356
To use it, sprinkle some iron filings on the area you suspect as cracked; then set the magnet on the surface and turn it on. The filings will move to show where the crack is.
Nice. Not sure if you are aware or not but when you check for cracks you need to check twice. The second time the magnet should be 90 degrees to how you had it set the first time. Magnetic particle testing can only detect cracks going perpendicular to the poles of the magnetic.
/ Show What Tool You Made* #25
Not sure I understand the logic behind that. Don't the lines of force follow an arc from 1 pole to the other. So the only time you would miss it is if the crack was very short and directly parallel to the magnet, centered between the poles but fairly far away? Ah the weaker the magnet the more likely that would be a problem too. His seems to be a very strong magnet.
/ Show What Tool You Made* #27
made a horizontal shaper to make panel cabinet doors, it holds three shaper cutters and does the milling on the stiles and rails and panels,
one can mill out a door in about 2 to 3 Min's, if all parts are cut,
I think the best thing about it is relative safe one would all most have to try to get one hand or fingers in it, and a standard shaper is not that safe,
I really like your shaper, does it cut the depth of the cut completely in one pass or is there a way to adjust it until you get the full cut you need? If it is adjustable what and how are the adjustments made? Does each cutter have it's own spindle or does it have a solid shaft that runs through all the bits at the same time, and if it is solid how do you add each cutter and tighten them up to hold them in place? I have a woodmaster planer and also a woodmaster drum sander, and there is a slight resemblance of the bones of a woodmaster planer in the shaper. I commend you on a neat setup.
/ Show What Tool You Made* #28
First it has been many years ago since I made it so this is close,
All the cutters have a bearing guide on the depth of cut,
It is one shaft, I think there is a shoulder on the shaft 1 shaft turned down to 3/4" and threaded on the end, is my guessing with out going out and measuring,
The cutters are stacked on using a number of spacers, and the non pulley bearing is clamped in as well, with a nut, and the other end is just locked in with the eccentric locking collar, locking the eccentric collar down after the nut was tight,,
The frame is (need to go look again, I will edit the post when I look later to day) the sides are 1/8" x 6" spaced with a angle iron, looked like 1 1/2" and the ends I think were 4 flat
the legs are angle iron,
The fences are wood on each end of the box that holds the shaft are two angle irons, top lip slotted the long way, other lip slotted vertical so the fences can be aligned to the cutters, all of the fences have a floor in them, that the product slides on that is nearly in line with the rub bearings, if one wanted perfection one would have to shim the ends of my fences, (one could make three short angles for individual alignment, I think I used Reversible Stile & Rail from Grizzly, C2314 Reversible Stile & Rail - Roman Ogee w/ Rub Collar, 3/4" Bore
On the end cut there is a sled with a clamp, that rides on the fence, and part of the trick is to have a back up (which is attached to the sled holder) so the ends do not split out,
I have set it up once and have not, changed the setting or the cutters,
personally I think if I really wanted a different profile I would make a new machine, or if I wanted more panel cutters, may be make one with all panel cutters, in it,
(now the RBI panel master claims to be able to run arched doors) my fences do not have that kind of adjustment and would think one would need a shaft for a starting guide on the cutter), when I have made arched doors I will set up the arch cuts on my shaper, really I do not think if I was rebuild or make a different machine that using end pieces that were lower one could make arched on the machine with a different guide fence,
If you have more questions, post and I will check back pm me if I do not respond I may have missed it,
I added pictures to show more of the constuction and the cutters and the rub bearings, hope this helps,
I am sure you are correct, but I had never thought of it. Thanks
/ Show What Tool You Made* #30
Here is a pantograph I built that gets a lot of use. Uses a regular hand torch the section of piano hinge to press the cut lever. Plexiglas is great if you only have a few parts because it is so easy to make a template or they can be made from steel so the magnet guides the torch around. The torch mounts unbolt and you can clamp a plasma in for other materials. Makes for easy cutting and faster to setup than the CNC table for just a few parts.
The speed control is a dash light dimmer out of an'86 RX7. The laminated paper next to it is a pressure/nozzle chart for the torch.
/ Show What Tool You Made* #31
some day I have told my self I want to build one of the pattern cutters,
what did you use for a motor and a magnet?
very simple on the hing to hold down the O2 lever,
/ Show What Tool You Made* #32
I build tools all of the time, thousands of them over the year. Just too many to post.
Click on this photo to play a video of a recent one.
NICE
VERY NICE
from the still picture I could not tell what it was and did not understnd the first time I read it, it was a video,
/ Show What Tool You Made* #33
The motor was just some old gear motor someone was throwing away. It's 24v but I am running it from 15v and less. The magnet is a "rare earth" one I picked up from a place that no longer exists. IIRC it is around 3/4" OD and 1/2" thick.
It's inside the aluminum part that mounts to the motor shaft below the steel mandrel (with heat shrink tubing on the tip for traction).
When I first tried it out it cut a straight like like this ~~~~~ because there was runout in the motor shaft, so I added the bearing over the aluminum part and all is well.
Went 20 years without it, can't imagine what I would have built by know with it early on. A Handyauto torch is nice for some things, a track torch for others but the pantograph is the most helpfull for the things I have done.
/ Show What Tool You Made* #34
yeah, photobucket used to have a frame their URL links were in that looked kind of 35mm so you could tell it was a video, now you just have to tell people to click on the photo.
/ Show What Tool You Made* #35
The zigzag pattern was for some targets I built.
These are videos too.
How it works
Edit you can see the difference with old uploaded photobucket videos
When you set it up in a match you block the bottom part, so the shooter is presented with this.
/ Show What Tool You Made* #36
Didn't make this one but did restore it and change the gauge.
It was originally made to check corner weights on race cars.
The round part is exactly 1 square inch surface area filled with oil where the gauge is threaded into. Incert a lever into the hole and lift to level. Gauge shows pounds per square inch.
Pretty handy scale and super simple. Use mostly for trailers and such.
/ Show What Tool You Made* #37
From left to right.
A 13/16 socket welded to the back side of a 7/8 socket so you always have the right size to remove lugnuts. You have to use it with a short extension.
Using a bolt welded to a socket to make an Allen wrench, the one shown was built instead of making a 24" 22mm allen wrench that cost $200 from Yamaha.
The last one is a bent wrench, that has a socket modified like the allen one next to it to remove Ford oil pressure senders, that they mount in places where you can't get to them. Think of it as a deep crows foot. The radiator hose and big ziptie is to hold the new one in place to install it.
/ Show What Tool You Made* #38
These are another two that get used a lot.
12" disk sander from an old 3/4 hp motor 3/8" aluminum and other scrap.
And one even the most budget minded guy will like, 1'x42" belt sander made from an old clothes dryer motor. The belt even runs where the dryer belt did, with idler pully. The top wheel is from an old roller skate and the stand was borrowed from a dead John Deere hay bailer.
Great stuff, jwmorris. I like the 2 sockets for lugnuts and the 1" belt sander. Thanks for posting them.
/ Show What Tool You Made* #40
Hydraulic press out of 6" channel iron with homemade press brake, note the drilled bolt for an easy way to release pressure.
A 2" receiver mount for a bench vice so you have one where you need it.
Trailmobile Van Trailer (A63689)
Trailmobile Van...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
