Mowing Tell me about my MF42 sickle bar mower
/ Tell me about my MF42 sickle bar mower #1
SmallAcre
Victoria
MF35
I picked up some old MF haying gear, and part of it is this MF42 sickle bar mower(or finger mower as they call them down here in Australia).
I cant find much info on this model - I managed to get a manual for an MF32 which is similar but not quite the same. These style of mowers appear to be more popular in the U.S. than down here these days, so am hoping someone can answer a couple of questions for me?
Firstly I need to replace an adjustable link(far right link in the circled section below), which is bent and metal fatigued, but I cant quite work out what the purpose of the mechanism it attaches to is for? Going from my MF32 manual I think its attached to something called a "gag link" assembly? Best guess I can come up with is that it lifts the end of the bar when the 3pt is raised? Is this correct?
Next, is there a height adjustable shoe missing from this end of the bar? I can see some cutting height adjustment from the inside shoe but cant see any on this end?
/ Tell me about my MF42 sickle bar mower #2
You are correct. It looks like you can remove it. Apply some heat and tap it flat again and reinstall. I've seen manuals to these on a regular basic on the US eBay site.
/ Tell me about my MF42 sickle bar mower #3
Go to www.agcopartsbook.com
Look to the top left BROWSE > BROWSE BOOKS > AGCO CORP > Massey Ferguson > Partsbook > Hay Equuipment > Mowers > 42
There you will find an exploded view of your mower where you can compare to see if any part is missing. If you are running IE9 then you probably have Microsoft Silverlight installed to view the diagrams. Then the diagrams can be zoomed and printed. The bar you mentioned first is listed in the diagram as a spring. It may be designed to look that way to absorb inertia when bringing the mower blade back to it's parked position. -robert
/ Tell me about my MF42 sickle bar mower #4
I looked up a 42 mower on agcopartsbooks.com and found the height shoe you speak of on the end of the bar is item #31 part no. 669471m91 and is called a runner assembly. The bent part is #15 and is called a stud - position lock part no. 581377m1.
Great thanks guys - unfortunately when I go to that site it tells me I need to register for an account through my local Agco dealership to access the parts books.
So does that mean I can still order these parts through an Agco dealer?
/ Tell me about my MF42 sickle bar mower #6
Look a little further down from the login and there is a "guest" login
/ Tell me about my MF42 sickle bar mower #7
Is there a box below the sign in box that says guest user? ours does. You should be able to order these parts through an AGCO dealer if the parts are still available but I would hope so since its not that old. They still have parts for the old tractors.
I must be getting a different login screen to you guys - I cant see any guest login :(
I tried changing my location to North America but it then just sits there trying to load and going no where.
/ Tell me about my MF42 sickle bar mower #9
It's possible that they have it blocked in your country. You're in Victoria Australia... correct? Seems like I recall someone else having the same trouble in the past, where they solved it by using a U.S. based proxy server...
/ Tell me about my MF42 sickle bar mower #10
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=306618"/>
What URL did you put in?
It should be http://www.agcopartsbook.com. Then use the Guest log in.
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2017 Ford Escape 4WD SUV (A59231)
2017 Ford Escape...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2015 Ford Focus Sedan (A59231)
2015 Ford Focus...
