hay tedder
/ hay tedder #1
mekongrabbit
Camden, SC
John Deere 4400; New Holland TN65
I have not used a tedder before but recently purchased a used Galfre GTS 280 2-basket tedder. The heighth adjustment seems self explanatory; however, there are adjustments above each basket that appear to be gear ratio adjustments. Am I correct? What is the difference between moving the adjustment forward (toward the tractor) or moving it toward the rear? Which would be the preferred adjustment?
I could experiment with it but would rather get advice from someone who is familiar with this tedder or a similar machine. I have a 9 acre Coastal field in central SC and think this tedder will be adequate for my needs, or will allow me to "cut my teeth" until I can upgrade to another tedder that has a wider swath or is newer. I appreciate any help.
/ hay tedder #2
Google this Galfre GTS 280 2-basket tedder adjustments - Google Search
Right under your post which was crawled with Google 42 minutes ago look at the goodwin concepts page. A pdf manual will open
with info on the Galfre Tedder operation and parts.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
2022 EZ-GO ELITE...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
