Oil Filter Comparison
/ Oil Filter Comparison #101
A little light reading about oil filter failures.
http://www.aftermarketsuppliers.org/Councils/Filter-Manufacturers-Council/TSBs-2/English/88-3R2.pdf
The last engine I built for my race car, a SBC 350, I replaced the oil pump. The pump instructions said that the over pressure hole on the side of the pump must not be restricted. The fact is that oil pumps are no different than a hydraulic pump in your tractor, two gears meshing. The pressures they can reach if the over pressure valve fails are in the 1000s of psi range. That's well beyond the range an oil filter can handle. Oil pumps are designed to dump the excess pressure out of the over pressure hole and back onto the oil pan. The flow of the pump is designed to include that oil flow as well as the oil going to the filter. If that hole gets plugged or the valve itself fails then it's up to the oil filter and the engine's bypass valve to deal with the excess flow and pressure. If you do a search for "collapsed oil filter" you find all sort of "don't buy Fram" sites but if you look a little further you'll find almost every brand filter collapsed.
/ Oil Filter Comparison #102
I guess that's why buying a heavy case filter like a K&N or a Mobil 1 makes sense in that application. When you've got your blood sweat and tears in a motor, a couple extra bucks for a filter makes sense to me.
/ Oil Filter Comparison #103
Agree 100% about the extra $$ for a quality filter is well spent. I change the oil and filter on my GMC once a year...what's an extra $5 for the K&N? And the heavy case makes it easier to remove the filter when you have to stick a screwdriver thru it for removal...:laughing:
I can get one, just didn't think that would be of interest to you guys. It can be telling of an engine I suppose, but didn't know if you could take much from it from a filter quality standpoint. What in particular are you looking for so I can try to get a picture that will be useful? Close up of the fibers?
I just wanted to see how close the pleats in the filter media were.
/ Oil Filter Comparison #105
There are huge differences between oils that just meet the minimum specifications and those that exceed the minimum specifications.
The same thing goes for filters
Statements like these are what results in folks searching the internet or talking to other people looking to uncover some "secret".
If an engine manufacturer comes up with a specification for an engine oil or filter, (or anything else for that matter), they don't come up with that set of specifications based upon the end-user operating that engine with kid gloves only under the optimum set of circumstances. Any "minimum spec" any engine manufacturer comes up with for an appropriate oil or filter, means that that specification is adequate.
Far too much of this "minimum spec" nonsense is used to sell stuff that isn't necessary and will provide no benefits. It's just as ridiculous as making a similar statement about a "minimum spec" for sizing the wiring in your home for a receptacle being inadequate.
So-called "minimum specs" simply are not teetering on the brink of failure like some folks, (and companies), want to you believe.
/ Oil Filter Comparison #106
Here you go Roger, is this what you were looking for?
/ Oil Filter Comparison #107
A cheap oil filter may save a little money now, but it can cost you dearly in the end. Been there, done that.
/ Oil Filter Comparison #108
I recall the ads Fram had at one time: "You can pay a little more now, or a lot more later" and it seems ironic now, given the negative reputation Fram seems to have for filters.
Just FYI here: I owned nothing but Ford products from 1978-1998, and used nothing but Fram oil filters in every engine my vehicles had. Back then Fram was considered a very good product and I had no misgivings whatsoever about the quality.
/ Oil Filter Comparison #109
As of right now i dont go looking for frams to use but if it is on a deal i get i use it on one of the older vehicles. I have to admit most of my hesitance is from this internet "lore" of them, BUT i do admit that looking into the filters i sometimes see plastic in them when i use to see metal in the same application, which has driven me away more than the so called falure stories that you hear on the net.. Massey being the first to actually say that it happened to him on one of his vehicles with a fram.
/ Oil Filter Comparison #111
The problem is that just because a part failed it doesn't mean that it was the cause of the failure. For example, if you run an engine without oil and you throw a rod you wouldn't blame the rod. However if the rod was defective and broke then you would blame it. The same is true for filters. People want to blame something but rarely actually take the time to find out what happened. When you see a spin on filter that's been cut open and the filter media has collapsed it's usually from one of two different failures. The first is that the filter's internal pressure relief valve didn't open while the second is that the oil pumps internal pressure regulation valve stuck closed.
Oil filter relief valves are usually set to about 12 psi. Since they just look at the pressure before and after the filter media (not the over all pressure) they are set to work with the type of media the filter. They are designed to deal with things like cold oil that will not flow through the media fast enough. Quick revving of the engine sending a rush of oil into the filter that creates a quick, but temporary, pressure spike, and for when the media or oil is old and dirty.
The oil pump pressure regulator is like the hydraulic pressure regulator on your tractor. It's job is to not let the hydraulic system's pressure go beyond a specific level. In your tractor it's probably 2500 psi or so. In your engine it's probably 80 psi or less. When working correctly and bleeding off extra pressure it's also allowing extra oil to flow back into the oil pan. When it fails it will send a spike in both pressure and oil flow into the filter. Filters are not designed to handle the increased flow and collapse. If the regulator valve stays stuck it can actually swell the steel sides of the filter housing and even blow out the filter gasket. If it's temporary and the regulator valve starts working again you may not notice, you may notice if you cut open the filter, or it could do enough damage to the filter so it blocks oil flow destroying the engine. An engine builder told me that older engines with bearings with wear on them are more likely to suffer a collapsed filter media since the oil has less resistance after the filter.
I was told when I was racing that special race filters were designed with regulator failures in mind and could flow the extra oil because they have an extra large oil bypass valve in the filter to deal with the high RPMs and sudden engine acceleration that race engines often see. I have yet to see any of these filter comparisons actually try to measure how much oil can flow through the bypass. It could be possible that the Fram filters do not allow enough oil to flow in bypass mode and that's why some fail or it could be simply because they are the most popular filter (because of their low price and abundance of sellers).
You're best defense is to change your oil and filter often no matter the brand or type of oil. Clean new oil will flow through a filter much easier than older oil. Older filter media will be partially blocked by the contaminates it has filtered out of the system. The more engine hours the more plugged it will be. In reality it's very rare and if you look around the internet you can find an example of almost every brand that has failed.
/ Oil Filter Comparison #112
In my case, when the Fram oil filter I posted about previously had failed, it was found that the filter's internal pressure relief valve didn't open as it should have. The oil pump was tested prior to dis-assembly and found to be working normally. In fact, the oil pump was undamaged and re-used after the engine was repaired, with no ill effects. In other words, I am 100% certain that the Fram oil filter was the case of the engine failure.
/ Oil Filter Comparison #113
A number of GM engines have their own internal oil bypass valve designed into the engine. Usually it's in the casting that the filter screws into. If you take the year, the model, and engine size to a web site like RockAuto.com you can do a quick search. If the engine was designed with the over pressure/ bypass valve built into the engine, not the filter then they should list the valve and even may have a picture of it.
What I've heard happens is companies like Fram cheap out. They just rely on the engines own bypass valve to work when needed and will use a filter that doesn't have the correct bypass valve. If you look at this picture from mike.
The sheet metal spring in that picture is the pressure relief valve. That filter's bypass is only designed to work in one direction. Oil must flow into the center of the filter.
In the second picture is a bypass valve that will work with oil flowing in both directions.
Lots of ifs here but if your engine had an internal oil bypass valve and Fram cheaped out and spec'd a filter that didn't have the 2 way bypass valve then your engine was doomed once the internal valve failed. If your Fram filter did have a back up two way bypass valve and both failed, that's bad luck. If your engine didn't have an internal bypass valve then clearly the Fram filter failed you.
The sheet metal spring is just for assembly, to hold against the bottom. The bypass is in the bottom. I think that the sheet metal spring over time will collapse and allow the filter to bypass. I have taken them off and heard them rattle. I think it is a poor design.
/ Oil Filter Comparison #115
To reduce the price Fram just combined the bypass valve and spring into one plate so they didn't need the coil spring.
/ Oil Filter Comparison #116
I worked maintenance at Pertro Canada on SouthDown Road Mississauga. Got to know the staff in the gasoline and lube oil test labs. Spent some time in there working on equipment. I can assure you that every tanker of 10W-30 lube oil,ATF and even wheel bearing grease is a unique and propriatory formulation. That GM, Ford, Chrysler, Toyoto and Honda etc specified. One size does not fit all.
That wood seem to apply to the oil filters to be used on certain Dodge trucks with the Cummins engine .The pistons have oil cooling holes in them and some oil filter manufacturers sell filters that are compatible (they fit). but when the non cellulose seal breaks down and is carried thru the oil system and makes its home in those cooling jets. It won't be Dodge who pays to rebuild or replace a cooked engine that normally would be expected to last in more than 350,000 miles... I admit this is an extreme example but it has happened...
/ Oil Filter Comparison #117
So-called "minimum specs" simply are not teetering on the brink of failiure like some folks, (and companies), want to you believe.
If the minimum wasn't good enough there wouldn't be a minimum.
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
