Where to buy Quick Hitch Bushings for Cat 1
   / Where to buy Quick Hitch Bushings for Cat 1 #1
Buty
Canton, GA
Kubota L3200
Looks like about $12.99 is least expensive I can find...Northern Tool. Anybody find any less expensive? Thanks.
   / Where to buy Quick Hitch Bushings for Cat 1 #2
Agri-supply.com , or 1-800-345-0169. Tifton , Statesboro, and Valdosta Georgia stores.
   / Where to buy Quick Hitch Bushings for Cat 1 #3
That looks like the lowest price I've seen. Belarus Ag Supply has them for less than $15 and they have a choice of Cat I to Cat II and Cat I to Cat III. Check shipping charges.
Quick Hitch Adapter Kits
   / Where to buy Quick Hitch Bushings for Cat 1 #4
I get them at Tractor Supply but I do not know how great of a price they are.
   / Where to buy Quick Hitch Bushings for Cat 1 #5
Hi,
Just wanted to let you know about another option. I use much less expensive bushings. They run about $2.29 a piece and they work great. You just slide them over your draw pin (the pins attached to your equipment where your lift arms connect). Then you attach the lynch pins, and they serve the exact same purpose that you need, and they are much less expensive. I have a set on all of my implements and they work great! I do like the quick hitch bushings, however they are hard for me to justify when I add up the quantity that I would need. They state that they are a hitch reduction, however they increase your cat-1 to a cat-2 connection just like he quick hitch bushings. Below is the link:
CountyLine® Category 2 to 1 Lift Arm Bushing - 0268454 | Tractor Supply Company
   / Where to buy Quick Hitch Bushings for Cat 1 #6
Wich do you need with land pride QH 15?
   / Where to buy Quick Hitch Bushings for Cat 1 #7
No. I got a set from Northern for that price. Went to TSC to see if they would match it and they could only do 25% off the original 34.99 price. I'll give it to them they really tried hard but that was the best they could do.
I'm planning on getting two more pair sometime here in the future. Its unbelievable how the same exact item can be so far apart in price.
Hi,
Interesting. I will look into this.
   / Where to buy Quick Hitch Bushings for Cat 1 #9
You need to measure the lower hook dimensions. If 1-7/16 inch pins will fit the hooks, you need to adapt to Category III dimensions. If 1-1/8" pins will fit, you need to adapt to Category II.
   / Where to buy Quick Hitch Bushings for Cat 1 #10
Thanks Kenny.
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
Takeuchi TL140 (A47384)
Takeuchi TL140...
