W.R. Long vs DIY 3rd function?
/ W.R. Long vs DIY 3rd function? #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
I'm wanting to add a 3rd function on my FEL for a grapple. I've got a L3710 with no remotes anywhere, so I'm starting with just the FEL valve (it does have PB). I like the kit the W.R Long has, but can I save $$ if I piece together my own kit? Would it be worth the trouble, or is it better to just go with W.R Long?
Thanks for any suggestions
/ W.R. Long vs DIY 3rd function? #2
you can build your own for less than half the cost of the wr long. Without any electrical components which are expensive to replace and are the weak link in a third function set up.
Looks simple enough. Is it just plumbed in the PB line? Can you explain how you did it and what parts you bought?
Thanks
/ W.R. Long vs DIY 3rd function? #5
Like that 3rd func. valve install teampryor:D Room for such is an issue on some tractors, like on my jd790.
I agree on the electric over hydraulic stuffs as "just something elts to go wrong". But in some cases its easier to run wires and a switch as the only feasible way room will allow.
Some of the people will tell you to only go with the WR LONG kit. It does however cost about $680.
You can find products equal to that setup. Here is something for your consideration.
Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
On top of this, what can I expect to spend? Never bought hoses/fittings, etc., so don't know how much they run.
Is there somewhere else I can find the "joystick" control like Long has?
/ W.R. Long vs DIY 3rd function? #7
If you want to go with a manual valve as teampryor said, just make sure the valve has PB port and everything is connected in series.
The solenoid valve mentioned above can be switched with a push button. The IN and OUT ports of the DO3 subplate can support about 5000 psi.
The solenoid valve would be mounted in a convenient place, in series with the PB from the FEL valve and then to the remote if you have them.
You can use both the solenoid valve and the FEL valve at the same time if the FEL valve is not using all the pump flow.
/ W.R. Long vs DIY 3rd function? #8
I've had an electric diverter on my 7520 for about 8 years now, no problems of any kind. It provides the luxury of being able to operate the diverter without having to take my hand off of the loader control lever. :thumbsup: That is a bit harder to do when you have all manually controlled valves. If you want to track everything down yourself, you can do it for about half or what the average pre made kit runs.
Good luck with your decision, whatever it may be ;)
Yeah, I really think I'd rather have the electrical control. I've run them on skid steers and like it.
So... in addition to the solenoid and subplate what else would I need?
For hydraulics, I'm thinking short hose/connector from PB to valve, hose from valve back to PB hookup on tractor, two hoses/connectors out to FEL.
For controls, where to find a joystick?
Anything else I'm not thinking of?
/ W.R. Long vs DIY 3rd function? #10
/ W.R. Long vs DIY 3rd function? #11
Do you need a true 3rd function, or can you get by with a diverter valve? A diverter is easier to plumb IMO. How about a control handle like this type?
Do you have a FEL now, and is it a manual valve.
Here is a joystick valve with PB.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE.
Surplus Center - BRAND POWER BEYOND KIT
Hose from FEL PB to IN port on subplate and hose from subplate OUT to the next valve, and two work port hoses to the grapple. Keep in mind that the grapple will be fast unless you needle valve the flow.
Yes, I've got a FEL with a 4way plus PB valve. I'd like a push button control like WR Long has - any good places to find that?
So...I'm a little confused here. I know if installing a manual valve for 3rd function it's important that it has a PB. But with the solenoid option, what maintains PB? Is that what the "open center" on the subplate does?
Thanks for putting up with my ignorant questions :)
/ W.R. Long vs DIY 3rd function? #15
The subplate ports are high pressure both IN and OUT, and will suffice as a PB port for the next valve downstream. It is placed in series with the other valves.
So I can take my existing PB line, essentially "cut" it in half and put this subplate in it (with the associated solenoid), and I'm good to go?
/ W.R. Long vs DIY 3rd function? #17
A hyd line can be considered a PB line if the source can handle high pressure, such as the PB port with PB fitting installed, or a hyd subplate.
You could cut your line and add new fittings, but most would just get new hose the irght size and make everything fit right.
Your flow might be something like this. Pump to FEL valve, PB out of FEL valve to 3ed function valve, then to remote valves, then to 3pt.
The first valve after the pump will have priority, and if it is using all the fluid, none will go through the PB port. If you use half lever, then the 3ed function can work at the same time as the FEL valve.
/ W.R. Long vs DIY 3rd function? #19
The only real "fun" part of the whole deal is finding the right fittings. The area gets tight in and around the FEL valve, so you will need to find the right mix of elbows/adapters/etc to make it all work. Kubota uses fittings that have O-ring seals and can be oriented after tightened for sealing.
ac
/ W.R. Long vs DIY 3rd function? #20
I think those o-ring fittings are called Boss fittings. The threads are straight and the o-ring provides the seal. I have found a wealth of fittings at discounthydraulichose.com.
Note: if a fitting is currently Boss, an NPT (pipe thread) can be used it its place, but I find that it alters the hole so that afterwards Boss no longer reliably works.
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
LOT OF PVC & PLASTIC PIPE (A63291)
LOT OF PVC &...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
