M/F 30E with power shuttle
/ M/F 30E with power shuttle #1
donbay
Festus,MO.
M/F 30E Powershuttle
MY tractor will not shift into drive nor is the power steering working. I changed the screen filter on the input side of the power steering pump and everything worked for about one hour then quit. I removed the filter and everything works. Does this indicate a weak PS pump? PS pump not available at parts stores but Massy wants $1800 for a new one.
/ M/F 30E with power shuttle #2
If the power steering works without the filter I would think the filter is dirty, perhaps you can remove it and clean and then see what happens.
Not sure if there is a procedure to check pressure from the pump, someone else on here may know and chime in.
If the price of a new pump from Massey dealer is holding you back on a purchase of a new one, see if you can find a rebuilder for the pump.
Clinton tractor salvage (Clinton Mo.) might have a used one ?? their number is ..... 800-769-5823
/ M/F 30E with power shuttle #3
Could you have gotten water into the fluid? Water will plug a filter that otherwise looks clear.Been there...suffered that! don-ohio
I changed the 12 gal. of fluid, changed the inline screen filter. The PS and power shuttle worked for a few minutes and then quit. i removed the screen filter and PS and power shuttle worked. I don't want to operate without the filter due to posably clogging the steering valve.
Thanks for the reply.
Don
Thanks ,Atlas Bob Cat has new pumps
Don
Fork Extensions (A65640)
Fork Extensions...
Bandit Wood Chipper (A62613)
Bandit Wood...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
