Catastrophic Failure
/ Catastrophic Failure
Well looking at the attachments it is a spring/check ball set up. It has to freely move to release hyd pressure. It has been suggested it might not have done that correctly
Thanks, DFB I'll take a look when I get it back.
I stopped by the welding shop Saturday morning and got bad news, the housing can't be welded or brazed. The shop owner said they tried several different things but as soon as they put any amount of heat to it the casting got hard and brittle. So on to plan "B".
I've been scowering the internet for salvage yards that have L2900s and found 3 so far. 2 were closed on Saturday but the 3rd has the part and want a little over 1/2 price of a new one. They also want the core back which means I'll have to pay freight twice between California and Iowa. I'll try the other yards today and see what they have to offer, both are closer to home too.
/ Catastrophic Failure #63
That sucks.. quite often cast will have so much oil in the pores that it's un-weldable too. If you knew for sure which other tractors used the same casting it would open up the scrapyard horizon quite a bit.
How much is the core charge? If they decide the old one is scrap metal you may lose that after paying for shipping, which would be a slap in the face. Might be better to tell them it's no good up front, eat the core charge and save the shipping. Just my thoughts, obviously.
Sean
/ Catastrophic Failure #64
Around here, when you buy auto parts from a wrecker, the most you will pay is 50% of new and then down from there as the vehicle gets older. I know its cars not tractors, but I would expect the same. 60% plus core plus shipping both ways, probably cheaper to go new.
Sean
He wasn't sure on the core price after I told him mine was cracked, I thought the same thing, eat the core charge and save the shipping. I looked up freight on UPS and its $72 one way, USPS will do it for $28 so I could at least save a little on return freight.
I've been trying to find out what other models use this cylinder, My service manual covers L2900, L3300, L3600 and L4200 so I downloaded the pdfs for them and they all use a the same cylinder, just not the same one as the L2900. I spoke to a yard in Alabama this morning, they have an L2900 and would be willing to sell me just the housing, no internals but needed to check it out before shooting me a price.
This experience has been an education. I'm discovering that a cracked hydraulic cylinder case is not as uncommon as I first beleived.
This particular case was used on the L2900, L3010, L3410, L3710 and L4310 (WARNING: Owners of these models may begin to experience feelings of paranoia while operating their 3pt, this is normal) and 4 of the 5 salvage yards that I have spoken to that had one or more of these models have told me that the case is either cracked or missing (sold). I've got 2 more yards to check but it's sounding like I'm going to have to pay to ship the one I found in California. (insert big sigh here).
/ Catastrophic Failure #67
What is a new part worth??
/ Catastrophic Failure #69
Pitbull somewhere along the line here you gave some thought to the damage being from physical 3 point abuse and at first you didnt think that was a possiblity do you have reason to believe otherwise now and that it not a pressure failure?
I asked all the yards if they had any insight into what would cause the part to fail and they all said the same thing, safety relief valve. So regardless of whether I buy a new case or a used one, the safety relief is getting replaced too.
/ Catastrophic Failure #71
It may be worthwhile bringing it to another welding shop to see if they can repair it. I worked with a guy once who could repair cast iron cracks when everyone else said it couldn't be done. No disrespect to your welder but another opinion could save you some money.
/ Catastrophic Failure #72
I doubt that it will be cost effective to have that properly welded. To get an effective full penetration weld will at a minimum require the cylinder to be remachined and likely welded from inside the cylinder also. I would think 4-5 hrs easy with no guarantee that it will hold.
Well, after contacting nearly a dozen salvage yards, only 2 have the case, the second one wants $450 for just the case and $650 with the internals :eek:. I decided to bite the bullet and called MyersWardTractor.com in California and told them I wanted the part.
$350 for the part, $75 freight and $100 core charge (recovered when I return the old part).
/ Catastrophic Failure #74
I don't understand why they want the old part back when its ruined. It doesn't make sense.
Where in SE Iowa are you? I'm located in Macomb Il.
Makes no sense to me either, I'm going to try negotiating it with them when they call tomorrow. My guess is if you don't return the part, they're up $100.
I'm in Burlington, how much snow did you end up with last night? We got about an inch of frozen slush.
/ Catastrophic Failure #76
Seems to me I'd want a new case, not a welded or junk one- the junk yard one has a real risk of the same thing happening if there has been any excessive pressure inside it prior to it being junked for other reasons. Not to say it has had a presence of overpressure, BUT do you really want to put a used case and new PRV in your tractor only to have it fail (possibly) not too far down the road? It seems like a $ and frustration nightmare waiting to happen. Then you have to do the same thing all over again?!
I'd want to go with new and peace of mind for the extra expense. JMHO
BTW, that's why they are called junk yards. Your decision- obviously, good luck with whatever you conclude- just playing devil's advocate here to level the choices out.
/ Catastrophic Failure #77
I agree, and with any luck Kubota has beefed that area up on the new parts.
/ Catastrophic Failure #78
We got about the same amount of snow. It came down really hard for a while but the ground was so warm a lot of it melted. Sounds like we may get quite a bit of snow tommorow. Good luck with the tractor.
/ Catastrophic Failure #79
Agreed. I would even go a bit further and start talking to the Kubota people to see if this is the case. Or what they have changed on newer versions to keep it from happening. You want to fix it better then new if you can.
I gave a great deal of thought to new vs used, but in the end I bought used. The biggest factor is cost, used is half price and I was able to negotiate the core charge from $100 to $25, return shipping via USPS is $28 so I'll just eat the core charge.
I strongly believe now that the failure was due to over pressure from a failed safety relief not from over pushing with the 3pt (they hadn't pushed with the 3pt at all the day of the failure), even a new part would fail if the safety fails. Also,someone suggested that there was a reason they're called "junk" yards, well I've bought alot of parts from junk yards in my life and just because a vehicle is junked doesn't mean every part of it is junk, IMHO.
That's it for now
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63118)
2021 Unverferth...
JOHN DEERE 10' ROTARY MOWER (A62130)
JOHN DEERE 10'...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
Like New! Low Hours! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Low...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
