What to look for when testing a used machine
   / What to look for when testing a used machine #1
Frank Sorbello
Gold Member
Power Trac PT-422
I test drove a 1999 PT-422 yesterday. Owner bought it used. Said the motor was rebuilt in the fall. It was very hard starting. Took quite a few shots of starting fluid. It has been out in the weather, not garaged. The fan on the oil cooler isn't working. I noticed a couple hoses needing to be replaced. One tire is dry rotted. I didn't notice any oil leaks. Hour meter not working. Couldn't tell whether wheel motors are okay or not. Needs a lot of TLC. What would you offer
   / What to look for when testing a used machine #2
If worse comes to worse, a new motor could run $1500.
Jump the oil cooler fan directly to a battery to see if the fan motor works. They are notorious for just blowing a fuse and/or the temp sensor that triggers it goes bad. If the fan motor is good, you can wire it to a switch and manually operate it(that's what I do with mine). If the fan motor is broken, $50-100 repair.
Hosed can be had from Surplus Center, farm stores, etc.... for not too much. However, some are custom lengths and not much room to leave a bunch of slack around and store bought come in 2' increments.
Get it running and warmed up for 20 minutes. Drive it around. Stop moving and turn the wheels lock-to-lock a few times to make sure it has full articulation.
Check the oil in the hydraulic tank and look for discoloration, dirt, etc...
Move the FEL fully many times.
Drive it up to a tree, push against the tree with the bucket, FEL, etc... and at full throttle see if you can spin the wheels or stall the motor. I can spin my wheels with turfs and sometimes stall the motor. If the wheels don't spin and the motor doesn't stall, there could be a chance that the wheel motors are just passing through fluid and not triggering bypasses, etc... its really kind of a feel thing.
They do not have the traction and lugging capabilities of a conventional tractor, so it won't be able to pull much. But it should accellerate to 8mph both forward and reverse eaily for mowing/tram speed.
On a flat level surface at full throttle with no feet on the pedals, the tractro should not creep in one direction or the other. It should hold still.
That is an old unit. It should have the hydroback cable pedal control that uses a cable operated by the foot treadle to move a lever on the variable volume pump connected to the engine. With the tractor off, operate the foot treadle several times in both directions to make sure it moves freely and you can't feel any binds or grinding.
Remove the access panels on the sides of the tunnel in the foot wells and look at the treadle assembly and see if it has bee greased regularly or if it is a rusty mess. Also inspect the ball joints on all of the articulated joints. Bounce the front and rear of the tractor up and down and see if it flexes up and down in the middle joint. It should not. If it does, that indicated either a loose joint that can be tightened with a large wrench (not a problem) or a worn joint that could fail ( a big problem).
Inspect all of the ball joints on the steering rams. You should be able to rotate them with your hands.
Does the unit have the quick attach feature or are the attachments connected with pins? The quick attach is worth its weight in gold and I wouldn't have a unit without it unless the unit was going to be dedicated to one task, or switched over once a season. I have to change implements often, so I need it.
That's about all I can think of. Good luck.
   / What to look for when testing a used machine #3
The choke might be stuck open. Easy fix, a little carb spray. Price wise, $1000. I have no idea what it's worth, just that's what I would offer.
   / What to look for when testing a used machine #4
I agree. It's 14 years old in unknown condition. Could be a fun project. Could be a money pit. Depends on your train of thought! :laughing:
   / What to look for when testing a used machine #5
Fan is controlled by a temperature sensor, so won't come on until the hydraulic oil hits 130F or so. Maybe you just didn't run enough to hit the setpoint. In cold weather, without using a PTO attachment, it could take quite a while to heat up that hot.
How cold was the weather? Stored outside like that, the need for starting fluid doesn't necessarily mean the engine was bad, maybe it just hadn't been run in the last few weeks.
Look at the hydraulic fluid in the tank, and check how dirty it is.
What attachments come with it?
   / What to look for when testing a used machine #6
I know when I bought mine I called Power Trac and talked to Terry. He told me what he thought it was worth. I think at that price it was a steal so I think it was good advice. I remember his biggest concern with my machine at about 1600 hrs was the Hydraulic pumps which he thought would be ok. He discouraged me from buying a 1430 that the same person had for sale because it had over 2000hrs on it and the pumps were the reason for his concern. He said the motor would be fine but the pumps could be an issue. I have close to 2000 hrs on mine now and everything is fine, but it does feel like it has some age on it. So now that I am done rambling I guess my advice is to talk to Terry.
   / What to look for when testing a used machine #7
Good advice.
So, I own a pt-422 as of 12:00 today. I think I got it for a fair price. The seller was very nice and honest. The machine needs a whole lot of TLC. Ideally, I wanted to purchase a new pt-425. I applied for a small business loan from my bank and another bank, however I was denied. Frustrated by the bank's decisions I knew I didn't want to go through the hassle of re-applying for another loan. I am hoping I won't be disappointed buying this machine.
Thanks for all your help,
Frank
   / What to look for when testing a used machine #9
good for you. Post some pictures of the new beast when you get a chance. :thumbsup:
She won't start. Don't want to use starting fluid on her.
   / What to look for when testing a used machine #12
Change the engine oil and filter.
Drain all the fuel.
Change the fuel filter.
Put some fresh gas in it.
Replace the plugs with correct gap and check for good spark before continuing.
   / What to look for when testing a used machine #13
Does the starter turn the engine?
Is the PTO switch on?
Is there a gas shut off switch?
Is battery good enough for whatever?
Check ground connections.
   / What to look for when testing a used machine #14
Is it below 40 deg F?
Is the choke opening and closing?
   / What to look for when testing a used machine #15
That depends... African or European Swallow? i dont know that! AHHHHHHHH!
I've been messing with this engine for several hours. I know it will start with starting fluid, but I want to find and fix the problem. The battery is new. The engine was rebuilt in the fall. When it is running, it does run and sound good. I drained all the gas out of the tank, fuel filter, carb and lines, and replaced with high test gas. Oil is fresh and at a good level. Spark plugs look good. The choke opens and closes good. When I turn the key, she sounds like she wants to start. You can see a puff of fire out of the breather and an occasional back fire. You could also see the carb spitting gas in to the breather. It was below 40 this morning when I first tried. In the afternoon the temp climbed to almost 50 and she still didn't want to start.
Thanks
Frank
   / What to look for when testing a used machine #17
Thanks
Frank
Below 40 mine will not start. I suspect 50 is marginal. Do you have a block heater? Also you can pull the plugs, warm them with a cigarette lighter and then reinstall them quickly while still warm. Then try to start. I keep mine in a heated garage.
Bob, Has your tractor always been that way? Doesn't make sense that it won't start below 40. Is it because of the hydraulic load the engine has to carry? Bob do you use starting fluid to start?
Very confused. Where is the tow valve located on the pump?
   / What to look for when testing a used machine #19
It has always been like this. I got a free upgrade from Robin Subaru that had improved ignition coils and a more powerful starter. They did not seem to help. My experience is very limited with cold starting since I keep it in a super insulated (R50) garage that is attached to the house. It very rarely gets below 60 F.
I think the hydraulic loading is slowing the cranking. I will see what I can find on the tow valve. Call Power Trac and they will help. They have the best telephone support.
I have a magnetic block heater which I attach to the hydraulic tank, but I have almost no experience using it.
I rarely use starting fluid.
   / What to look for when testing a used machine #20
Replace them anyway and make sure the gap is correct. For that matter, you may want to get one size hotter just to get it running, then once its tuned up see if you can go back to the correct temperature plugs.
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2024 CASE TV450B SKID STEER (A60429)
2024 CASE TV450B...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
