Grapple Can I use my rear remote to operate a grapple?
   / Can I use my rear remote to operate a grapple? #1
ppinnick
Bridgeport, AL
Mahindra 5010 CAB HST
Good Morning All,
I have a Mahindra 5010 HST with an auxillary remote on the back end. Can I use that remote as a 3rd for mounting a grapple to my FEL?
I know opening/closing the grapple won't be as convenient as mounting a 3rd up-front with a toggle on my loader joystick, but is there any issue with running hydraulic hoses from back to front? I was told: 1) should NOT run hoses that long and 2) the rear flow rate wouldn't support grapple operation and that I needed to add a 3rd to my FEL. Is this true, or is someone just trying to sell me an unneeded uprade?
Would gladly trade the inconvenience to save the money if I am not going to damage my hydraulics.
Thanks, PmP
   / Can I use my rear remote to operate a grapple? #3
Good Morning All,
Thanks, PmP
I run a square bale grabber using my rear spool with no problem! $300 for the hoses and couplers was alot cheaper than the $2k the dealer wanted for the 3rd function kit. The hoses do look god aweful though!
   / Can I use my rear remote to operate a grapple? #4
Who told you those things? If it was a dealer than go elsewhere! The fluid won't care how long the hoses are, and a grapple cylinder hardly needs any flow at all. 1/4" hoses are all you need, anything larger is a waste of money and space.
   / Can I use my rear remote to operate a grapple? #5
Agreed.
   / Can I use my rear remote to operate a grapple? #6
X2. Fluid don't care! I like that.
Travis
No, not a dealer. Just a neighbor who apparently likes to spend my money! Thanks to all for the advice, PmP
   / Can I use my rear remote to operate a grapple? #8
Yup what they say ^ - I had mine with long 1/4" hoses from the rear for a long time. Didn't even look bad. Put a 90 pointing down just after the QDs in back and ran the hose under neath along the frame and then followed the loader hoses up from the hydraulic block to the loader valve and down to the bucket cylinders. Nothing hanging down to get caught and out of sight. Used tie wraps to hook them to frame bracing and loader hoses.
   / Can I use my rear remote to operate a grapple? #9
What would control the open and close of the grapple? I have hydraulics on the back of my tractor but no control. Controls are on the hoe for functions.
   / Can I use my rear remote to operate a grapple? #10
What you have is called "Power Beyond", a continuous flow of hydraulic oil whenever the tractor is running for things that have their own valves like backhoes and logsplitters.
These guys have a "extra" valve on their machine's to control cylinders on attachments. It's called a "remote" or "SCV"
Year: 2016 Make: Volkswagen Model: Jetta Vehicle Type: Passenger Car Mileage: 106,836 Plate: Body (A55853)
Year: 2016 Make...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A55314)
2022 Brush Wolf...
402 (A52706)
402 (A52706)
Jeep Metal Tailgate Art (A55853)
Jeep Metal...
