S185 Wiper Blade substitution
   / S185 Wiper Blade substitution #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Just had to replace a wiper blade on a 2008 S185. The standard blade from an automotive application wouldn't work because the pin on the wiper arm is too short to go completely through the attachment point. The blade would wiggle back and forth until it pulled off of the wiper arm.
I wound up getting a blade from Bobcat (7147359) but it was about $20 plus tax.
Is there anyplace to cross reference the number to find a lower cost blade in the future?
   / S185 Wiper Blade substitution #4
Could you refill it instead of replacing it?
Not sure. I think I might have chucked the blade that was on the machine after I bought the automotive one. Now that I've gone and replaced the blade with a Bobcat part, a refill might be worth looking into next time around if anyone still makes those.
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
Cat TH407C Telehandler (A51039)
Cat TH407C...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
