Buying Advice John Deere model 770
/ John Deere model 770 #1
Blacklion
Weeki Wachee, Florida
Model 770
I have an opportunity to purchase a 1998 Model 770 John Deere 2wd diesel with turf tires. It has 330 original hours with a front end loader and a 3pt hitch (not sure if hitch works, goes up but can't lower it). Tractor was stored outdoors and has various rust spots and total seat deteoration. The seller wants $4,000.00. Is this a wise purchase?? Thanks for your input.
/ John Deere model 770 #2
Depending on your intended use, I think you would do just fine. Unless it was abused, it's barely broken in. Attaching an implement will lower the three point. Gravity does the lowering.
/ John Deere model 770 #3
The links should lower though...even with no implement attached. I suspect the rate of drop knob (on the panel directly below the seat) may be closed.
Anyway, to the OP...the 770 is a very basic and very nice little tractor. It shares many components with the current 3005 Deere.
2WD will be a bit of a sticking point for two reasons:
the 770 is a lightweight and you will run out of traction. You will want rear ballast on the 3PH.
Steering with 2WD and a full load in the bucket will become tiring. Do ensure the tractor has hydro-assist (power) steering. This was an optioon on the 2WD machines.
Since you're from Florida, snow removal isn't in your future. I suspect mowing and (maybe) some field mowing (brush cutting) is...the 770 can easily handle a 5' or even a 6' finishing mower. It can handle a 5' rotary cutter, but thick brush will really require slowing down.
$4K is a pretty good price...good luck and don't wait too long.
