new snow blower user
/ new snow blower user #1
boyajm
Cumberland, RI
Ariens 921 series 28"
I have an arien's 921 series, 28" snowblower. I find I am using way too much upper body trying to propel this forward. Am I supposed to use it with the right wheel pin in the lock position or unlocked? If is has too be locked then do I unlock it every time have to turn it?
Thanks, Mary
/ new snow blower user #2
leave the wheels locked for snow blowing operation. it'll be tougher turning around, but that's OK.
the only time I unlocked mine was for ease of moving it around during the off-season.
Pete
/ new snow blower user #3
Not trying to sound negative but I bought a brand new walk-behind about 6 years ago to clear our drive. I found that if we got anything over about 4 inches, it was a real chore. I had a 32 inch, 10.5 horsepower unit. It took so much energy to run the machine that it was almost as easy to use a shovel. This was on a meduim sized paved driveway but we got really bad snow drifts there (no longer live there). I ended up selling it for a loss shortly after buying it and getting a used blower for the garden tractor. The blower for the tractor cost a quarter what the walk-behind did and it came with tire chains and wheel weights. It was much easier on my body also. I don't think the newer walk-behind blowers have the weight and mass that the older ones had. The power is there but the traction isn't. Just my 2 cents.
/ new snow blower user #5
I had the same issue with wheeled blowers that I used for the smaller areas. I got one of these and it is unstoppable: Honda Snowblowers: HS928TAS Two-stage Snowblower
That's a nice blower! I could buy a blower with a tractor attached to it for that price though. I guess if you don't have a need for a tractor and/or a place to store it that would be a nice option.
Thanks. I will lock the wheel tomorrow and hope that helps a lot. Only have used this once before, but that was for a 3" storm. It wasn't happy with 25+.
/ new snow blower user #7
It will be easier if you go slow and sometimes a slight up and down motion helps in deep stuff. I have tire chains on mine which help, but either way it is still a good workout. If its tough to push also check your sheer pins, maybe one half isn't turning.
/ new snow blower user #8
I agree... deep snow and drifts are tough to get thru. Fresh light snow is usually a breeze.
I too used to fight with the thing, usually now I just run it in a low speed and try to guide it but sometimes have to wiggle it as tractchores suggests to help cut thru the heavy stuff. The pin I sheared most often is the one on the right wheel lock gizmo.
Pete
/ new snow blower user #9
It's kind of a "catch 22" in that you need to have the wheels locked for maximum pulling power, but it's hard to turn, and who wants to keep locking and unlocking the wheels? I learned to give the handles a good yank at the end of each pass to spin it around. Blowing deep or wet snow will definitely give you a workout, and as said before go slow, and maybe take less than a full width each pass. It's usually better than shoveling, but it can be a love/hate relationship!
/ new snow blower user #10
Make sure you have a good set of chains on it, put it in reverse when turning around and take your time. It really does have more power than you.
2004 John Deere 4720 (A60462)
2004 John Deere...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2017 International 4300 Box Truck (A62613)
2017 International...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
John Deere 6400 (A64126)
John Deere 6400...
