I bent some rod into hooks... Now What?
/ I bent some rod into hooks... Now What? #21
A Co. I do some work for bent about 100 rod hooks to hang metal doors on for painting heated bent dropped into water they all broke next re do and air cool they are all working several years later.
/ I bent some rod into hooks... Now What? #22
it's that whole big crystal vs small crystal thing..
Do tell. What's the big crystal vs. small crystal thing? Which method creates which condition and what are the consequences?
/ I bent some rod into hooks... Now What? #24
slow cool makes larger grains usually.. thus more ductile.. but softer.
fast cool makes smaller grains.. generally a bit 'harder' ( carefull on that term ), but also more brittle.
For instance.. some metals work harden and get brittle easilly.. like copper.. and then you can aneal them by heating and slow cooling.. etc..
i'm not a that kind of an engineer (mechanical).. but that's the 'farmer 101' version of it....
soundguy
/ I bent some rod into hooks... Now What? #25
prolly would advise quenching them, my dad was a blacksmith, he heated thingsof that nature to a dark cherry color then quenched them in used hydraulic fluid, no explosions or flash fires, careful not to get it on you.used hydraulic fluid has some weird prperties, one of wichis a contact carcinogen.comes from high exposure but why take a chance?
/ I bent some rod into hooks... Now What? #26
I built this cart last summer. Mostly from scrap steel from work. Wheels came from a friends old sprayer. He gave them to me. Bought the seat at a junkyard for $35, shafts from the Amish around $30. Had to put in new wheel bearings on one wheel. Have approx. $100 into it. Not a pretty cart but quite comfortable to ride on. I like sitting up high because easier to see. Luke is Percheron/Quarter horse cross. He is 17 hands and guessing around 1600 lbs.
/ I bent some rod into hooks... Now What? #27
Good looking sulky. Being up there in the air like that also gets you out of the exhaust plume. :D
That's a pretty nice cart. Nice looking horse, too.
/ I bent some rod into hooks... Now What? #29
Put a hitch on the back of that cart and you can do tractor work.
OP: Those mild steel hooks won't harden and they don't need it. What you did is perfect. Since the radius at the bottom of the hooks is small, it will take a lot more than a pony to straighten them out.
LOT LOCATIONS (A59905)
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2012 POLARIS SPORTSMAN 500 H.O LIMITED EDITION ATV (A60432)
2012 POLARIS...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
set of 4 tractor trailer tires Roadforce (A61306)
set of 4 tractor...
1999 REITNOUER 96"X48' FLATBED TRAILER (A60430)
1999 REITNOUER...
