Rear Blade What size rear blade for my John Deere 1026?
   / What size rear blade for my John Deere 1026?
What is a RB0560? The landpride 1560 does not tilt. He is going to get me a price on the one that tilts RB1660 Saturday. Is woods as good as landpride?
   / What size rear blade for my John Deere 1026? #63
The RB0560 is rated for tractors up to 25hp. It is more of a SCUT only blade. It only weighs 143 pound and has a 13.5'' high moldboard. The 1560 is rated for tractors upto 40hp but I would not use it on anything that big. It is a good blade for a SCUT or a small compact like a Kubota B series or a JD 2000 series. It has a 14'' high moldboard and weighs 248 pounds. The RB1660 is pretty much the 15 series but it tilts, it weighs 283 pounds. All 3 of these LP blades have a 1/4 thick mold board. The Woods RB60 weighs 262 pounds. Their website says it has a 3/16 moldboard but mine has a 1/4." Either it is a miss print or since mine is older it is thicker. The Woods blade only have a 3 position tilt 15* left, 0* and 15* right. It looks like LP's website says the 1660 will tilt in 5 positions: 15* left, 7.5* left 0* 7.5* right and 15* right. I think the LP is braced wider where it bolt to the moldboard the the Woods RB60. The woods blade would be fine for your tractor or even a little bigger. Woods uses a better park stand, I think. The Woods rb60, LP 1560 or 1660 would all be a very nice blade for you.
   / What size rear blade for my John Deere 1026? #64
Land pride makes some good implements. Hey Roger, have you heard anything from Creekbend?
   / What size rear blade for my John Deere 1026? #65
I wanted to reiterate that I am not sure if a blade tilt on your tractor. You should do some measuring and calculating before you spend the $$$$ for tilt. My BX lift arms are 26 1/4" to the center of the ball and 27 3/8" to the center the QH fully raised and my Woods RB60 will tilt.
I put my draw bar on and raised my lift arms up all the way and measured the center, its 24 1/2" will a tilt blade work?
   / What size rear blade for my John Deere 1026? #67
That was how I measured mine. Was that measurement to the quick hitch or lift arms. I am going to have the blade on toady I will raise it to 24.5" and see if mine will tilt.
Roger, I got my quick hitch on, I raised it up as high as it would go and measured from the center of the draw bar to the ground and that's 24 1/2".
   / What size rear blade for my John Deere 1026? #69
Here is how the blade was sitting before I raised it. It is sitting a little low in the front but it is close to level.
Here is the blade @ 24.5"
A closer shot, a 2x4 just barely slide under it so there was a hair more than 1.5" of clearance
This picture is without the blade tilted.
You can use these pictures as a idea. It may vary some on your tractor.
Thanks for all your time taking the pics for me, I really appreciate you and everyone else that has been trying to help me make a decision.
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
2011 CONTRACT MANUFACTURER 14 T/A ENCLOSED CARGO TRAILER (A55745)
2011 CONTRACT...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
Deere 35P (A53317)
Deere 35P (A53317)
TRANSMISSION FLOOR JACK (A55745)
TRANSMISSION FLOOR...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
