Lift will not go down.
/ Lift will not go down. #1
aea
Florala, AL
kubota L5030
I have a kubota L5030 and the rear hydraulic lift is stuck in the raised position, any ideas on how to get it down.
/ Lift will not go down. #3
Under the front of the seat is a Knob that controls the drop rate of the 3pt hitch. Rotate the knob counterclockwise. (toward the rabbit direction) you probably accidentally rotated it clockwise with your foot. to the point that the 3pt does not want to drop at all. Give it a try.
James K0UA
/ Lift will not go down. #4
I have an L5030 that had the same problem. Turning the lever fixed it! Never knew what it was for. Thanks for posting a response with a resolution.
