Getting mad
/ Getting mad
So I put the new one in started right so I went over to pull out more wood . Then I shut the tractor off to use the chainsaw then loaded the wood in the bucket then went start and again nothing I had to take it a part to clean and put it back together to start the tractor. I 'm going to call the dealer to see when the update ignition switches are coming.
/ Getting mad #82
I feel your pain Nate
/ Getting mad #84
That's a real bummer. I can understand your frustration and I felt your pain with my CK30. Sometimes I think a machine is just cursed, no other way to explain it. I was very leary buying a second Kioti just to get out of a bad first experience with one, but with 85hrs on the clock of the DK45, not a single problem I didn't cause. Hopefully once you get the ignition sorted out you have the same experience. Have you priced out an ignition from CAT as was suggested?
/ Getting mad #85
To Landed a Kioti,I don`t believe they would have a left over 2010 tractor when you bought your tractor but stranger things have happened.They wouldn`t have a leg to stand on if they misrepresented the year of the tractor because you have the contract with year of the tractor right on it and of course you have the manufacturers plate located somewhere on the frame with the build date right on it!
/ Getting mad #86
Tractors don't have models years the same way cars do. There is simply a manufacturing date of the tractor. There is no difference between a 2010/11/12/13 DK 40 for instance. I'm not saying it doesn't matter, I'd want one built the same year I bought it, but you can't go back to them on model year.
/ Getting mad #87
To answer your question, I grew up not too far from where you are, on what today would be today be called a subsistence farm. In the 30's and 40's it was called "dirt poor".
I am not questioning your (or your families) philanthropy nor your benevolence, just your veracity.
You "jump ugly" pretty quick.[/QUOTE
Wow that is some good talking out of both sides of the mouth.
/ Getting mad #88
So I put the new one in started right so I went over to pull out more wood . Then I shut the tractor off to use the chainsaw then loaded the wood in the bucket then went start and again nothing I had to take it a part to clean and put it back together to start the tractor...
lande ... there must be something else going on here other than just the switch. A new switch can't go bad in such a short time. Maybe juggling the wires to work on the switch restores a break in the wires, or something. A Diesel will run just fine regardless of the electrical system (except for the stop solenoid) so it's quite possible that the problem in your start system returned seconds after starting the engine.
/ Getting mad
When I opened up the new one the copper had greenish tint on it. I do think there is something else I talk to a dealer that are still waiting for the updated switches. When they get them from kioti they will come and install it and test everything else.
/ Getting mad #90
Did they send you a new switch or an old one they took out of somebody elses tractor? That doesn't sound like a new part to me.
/ Getting mad #91
Good point, sounds fishy to me. Is a Kioti dealer that bad of a company to send old parts to a person? And a new part fail that quickly? Plot thickens.
Do you leave the tractor outside uncovered exposed to the elements? Use some dielectric grease on the contacts keeps the water out and them from turning green. https://www.google.com/search?q=electrical+grease&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:eek:fficial&client=firefox-a#hl=en&sugexp=les%3B&gs_rn=1&gs_ri=serp&gs_mss=delectrical%20grease&pq=electrical%20grease&cp=2&gs_id=1m&xhr=t&q=dielectric+grease&es_nrs=true&pf=p&client=firefox-a&hs=ip2&tbo=d&rls=org.mozilla:en-US%3Aofficial&sclient=psy-ab&oq=dielectrical+grease&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41642243,d.aWM&fp=cb613fd398c77cdc&biw=1024&bih=638
Odd the switches don't have the dielectric in them already. Use a large piece of heat shrink tubing and hermetically seal the switch too.
/ Getting mad
I think they took one out of a tractor on the lot because kioti corp hasn't sent the updated switches it was in hopes to get me by why I wait for the updated one.
/ Getting mad #93
Connie is out for you Nate.
/ Getting mad #95
As to the date coding on the switch harness: often assemblies such as that cable are made by subcontractors who for best pricing need to make in batches of 1000, 5000 etc.
and often a manufacturer simply buys the larger quantity if he feels that he can well afford to stock a couple of years worth. Many times the set up charges can be the highest part of the cost which then gets better and better with volume.
Same as with hardware. A handy pack consisting of 5 bolts might be $2.00 and the same bolts sell for $5.00 per hundred. Packaging, stocking and handling is what does it.
/ Getting mad #96
OK, sorry to bring this thread out of the trash for a minute. LAK, your luck stinks but here's what you should really be taking away from this. Even though it didn't work out, you now have a dealer who was willing to go out of his way to get you a solution by ripping a switch out of one of his tractors. It's too bad the switch didn't work for you, but he is trying to make it right and that's the kind of dealer you need to work with. As was mentioned, maybe the switch has nothing to do with the real problem, and if that's true, you're going to need the services of a good dealer.
OK, sorry to interrupt. Resume the rants, grumpiness and bitterness over being called a troll. Gentlemen...
/ Getting mad
KK,
I talked to kioti corp today and the dealer. The dealer should be get the new switch next week then they will come to the house to install and test other things to make share everything is working right. I like Whittemore and son dealer in Maine. Very nice dealer. Also the guy I talked to at kioti a lot nicer then Connie. I like dealing with him very helpful.
/ Getting mad #99
good riddence
/ Getting mad #100
With Connie gone there is a chance of getting through to someone who might actually help owners of Kioti tractors.
I'll second the motion to say adios to her for sure.
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
