3240 w/cab rear blade?
/ 3240 w/cab rear blade? #1
coldfingers
Warren, Mn.
2013 Kubota RTVX-1120D, kubota ZG 227, kubota LX 2610
Going to use it for snow removal mainly but some gravel blading also. Which width rear blade would you go with? Six foot good ?
Thanks.
/ 3240 w/cab rear blade? #2
I have a B3000 with a 6' blade. It seems like the right size for my tractor.
/ 3240 w/cab rear blade? #3
I have L3940, basically same width as your L3240. I have, and recommend, a 7' rear blade, so when angled, it will be just a little wider than your tractor. Now for box scrapper, I recommend 6'. Philip.
/ 3240 w/cab rear blade? #4
i have an 8 foot on a 7040 tractor if you try to move dirt spilling over the back of the blade the tractor will stall with a 7 foot on it i had my 8 foot hook to my l3800 it stop it dead
/ 3240 w/cab rear blade? #5
You want the 7 footer for snow removal to clear the tires.
Sean
/ 3240 w/cab rear blade? #6
7 footer on our L3240 is just right for snow work. Does pretty good in the soil, too.
/ 3240 w/cab rear blade? #7
Kubota only recommends a 6' blade but i would go with a 7' so it wider than your rear tires when angled. Be sure you get something that is fairly heavy duty so you don't tear it up.
/ 3240 w/cab rear blade? #8
Good point. At 7 feet, the cheaper/lighter blades will cost you in the long run.
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
Dexter trailer axles (A61567)
Dexter trailer...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
