Kubota front loader cylinders
/ Kubota front loader cylinders #1
toyotadriver
Member
Kansas City, KS
Kubota L2350DT
I have a Kubota L2350DT with front end loader (I can't remember what the model of the loader is but I bet someone here does know). Anyway, one of the cylinders is slowly leaking. I think another cylinder may also be leaking as well. I'd like to replace all 4 of them. Or rebuild them. They appear to be welded so I don't know if they can even be rebuilt.
So, rebuild or replace?
If replace, where should I look for new ones?
Thanks in advance!!
/ Kubota front loader cylinders #2
tough to find other then originals and they are rebuildable.
/ Kubota front loader cylinders #3
I'd say rebuild or have a hydraulic shop rebuild them. You will be way ahead money wise.
MarkV
/ Kubota front loader cylinders #4
toyotadriver, Looked and couldn't find your loader #. Just hang on awhile someone well see this and might be able to help. Where does your loader pickup the hyd pressure and where does it return to tank? A friend has one and was asking me and I'm not 100% sure yet. Maybe after I look it over I might be able to tell him. Thanks Lee
/ Kubota front loader cylinders #5
Thanks in advance!!
Why not just get the seal kits for both cyl and fix what needs fixed and save the other kit for when the other one breaks.
Is it an inside leak or outside leak?
One has a small leak out and I think that a couple of the others are leaking within. I'd like to rebuild all of them.
I guess the loader model is an LB400.
Here's a pic of the tractor:
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59906)
2022 KAUFMAN 4X2 2...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
