5083e anti sway kit installation help
   / 5083e anti sway kit installation help #1
mtncur
Member
Grand Rivers, Kentucky
John Deere 5083e, Kubota L3240
I recently picked up a used anti sway kit for my 2011 5083e. On the John Deere configurator it is part number BLV10121. The problem is the brackets that the factory installed anti sway chains won't work with this kit. I do have the brackets (came with the upgrade I bought) however no mounting hardware. The mounting hardware (bolts and bracket) are different for the chains. I haven't been able to find any photos (even of the kit) on the web. I was wondering if anybody has this kit installed on their e series and if they could share some photos so I could see how the brackets install on the axles. Your help is appreciated.
   / 5083e anti sway kit installation help #2
BLV10121 doesn't show up as a good part number. Maybe this will help.
19M9318 Cap Screw 8 M16 X 230
   / 5083e anti sway kit installation help #3
Can you post pictures of the parts you bought?
Jim,
The schematic you posted is what I currently have. Everything on it gets replaced with the anti sway (telescoping) kit. The issue is the bracket (part 11) will be replaced with the new one and i don't have the hardware (3 and 5). The old bracket is threaded the new one isn't. I was hoping to see a schematic with the new anti sway kit so I could see how the new bracket is mounted.
   / 5083e anti sway kit installation help #6
Ok I'll try again.19M7793 Screw 4 M16 X 40
Yes, this helps, it's exactly what I have. Looks like I'm missing 2 bolts (part 8). I was thinking there was another bracket part that wrapped around the axle like the old one, but this looks like just 2 bolts that thread into the bottom of the axle.
   / 5083e anti sway kit installation help #8
Second picture is similar to what my 6415 has. If your axle housing is drilled and tapped you will be fine.
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
PALLET OF PICKUP HITCHES (A50854)
PALLET OF PICKUP...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
