Oil Filter Comparison
/ Oil Filter Comparison #41
I use wix/napa on all my vehicles.
On the 790, the price differents is little of deere vs. wix/napa...... 790 gets the deere filters
/ Oil Filter Comparison #42
Guys/gals I'll tell you the sad truth......I have a HARD time passing up the FRAM toughgard with the abrasive black coating on it's end. For one thing,I think,hey,it's FRAM! But the SELLIN' thing is I can spin it off without a tool even if my hands are a lil'oily.
So, yeah, my backhoe gets NAPA or WIX,but my Mustang,Aerostar,Lincoln and Ford 250 usually end up with a FRAM.Just have a hard time resisting that easy change feature. LOL! don-ohio :)^)
Buy a Spray can of truck bed coating and spray the Wix yourself.
/ Oil Filter Comparison #44
I use PURE POWER or System One Filters have for years and they last a LIFETIME All you do is take them apart clean in a parts washer then soapy HOT water blow dry with compressed air put back together and save your money in the long turm get cleaner oil better flow and they don't end up in a landfill.
Does that leave a roughened coating? Sounds like a plan! Thanks! don-ohio :)^)
The duplicolor kind leaves a fairly rough coating. I guess it will hold up to heat:confused3:
/ Oil Filter Comparison #47
Thanks,94B! Worth a try! Never woulda'thought of that. don-ohio :)^)
/ Oil Filter Comparison #49
Hi , I just bought a new 2013 massey ferguson GC 1710 . It replaced the GC 2610,2410,2310 . I found I need a NAPA GOLD 1360 engine oil filter , but what Hydraullic oil filter do I need , also what air filter do I need as the owners manuals tells nothing !! Thanks Bud
/ Oil Filter Comparison #50
wip in paint.. roll in some grit? ;)
A lot of the times the hydraulic filters are only availabke at the dealer. If you had the number you may be able to cross it over. If you ask in the MF forum someone may k,now.
/ Oil Filter Comparison #52
speaking of filter oem brands.. etc.
I was picking up an oil filter for my yukon.. pf61 is the ac delco OE filter. it was 40 cents cheaper than the purolater and the fram filter setting next to it on the shelf.
Looking at the filter.. feeling it.. weight..e tc. I'd BET the fram extra guard ( which was the most expensive of the 3 ) was a better filter. but heck.. i figure you can't go wrong with the ac delco filter in the book for your truck.. etc.
On ford. look at the fl1a motorcraft filter. it crosses to ph8a fram, st8a supertech.. napa 1515 auto application, 1452 other appl..e tc.
the fl1a can be had for 2.99$ in some places.... that's cheaper than any of it's cross reference.
I have seen people on the internet (so I can't confirm) saying that the same company that makes the filters for AC Delco also make the STP filters. The STP filters are usually the cheapest filters on the shelves. They could be made differently, or maybe not?
/ Oil Filter Comparison #53
i know the stp and ac delco filter are close in price at walmart for my yukon.. with the fram being a tad more.. just frome weight.. the fram weighs more too
/ Oil Filter Comparison #54
/ Oil Filter Comparison #55
you can say that again!
/ Oil Filter Comparison #56
i'm not sure why it double posted.. but assume it was part of the board hiccup that happend. I didn't purposefully double post.
/ Oil Filter Comparison #57
I know it wasn't on purpose, I see it all the time, just for some reason this time I had to make a comment.
/ Oil Filter Comparison #59
Yea we still are dealing with that double post issue? I have done it a few times myself i see recently?? What happended to the outcome of that Dbl post thread we had like a year ago going and Muhhamad was "looking " into it?
/ Oil Filter Comparison #60
Heck the coating on a fram if oil gets on it and with the heat and time it flakes off.
they have been holding up for me on a tractor.. 1 year anyway. though no oil gets on them.
a lil gas sometimes from over choke though.
they are cheap enough to chage out more often if they do get damaged though.. :)
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
1996 John Deere 8400 (A64126)
1996 John Deere...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
