Grand L 4240 for Grapple Work
/ Grand L 4240 for Grapple Work #21
I think he will find a L4240 is more usable with the dual speed hydro. You can do just about anything in medium range.
I like all aspects of the HST+, but use the dual speed switch more than any of them.
/ Grand L 4240 for Grapple Work #23
I think the 4240 would be fantastic for grapple work (with the proper ballast).
I have the rear tires filled and a 600lb box blade that I have been using for ballast on the MX. Will that be sufficient for the 4240?
/ Grand L 4240 for Grapple Work #25
It would be sufficient in most cases.
I have rear tires filled with methanol and a 550lb scraper blade.
I think what I have is pretty close to that. From looking at the specs I don't think there is enough size and weight difference between the MX and the 4240 for me to notice. I think the MX is a little more than 100 lbs or so heavier but I suspect that a lot of that is in the front axle. I am guessing the FEL and grapple performance should be nearly the same.
/ Grand L 4240 for Grapple Work #27
I think the overall performance of the tractors will be about the same (maybe a hair better on the 4240 because of HST+) unless it is something that requires the extra PTO power. I would gladly trade 8hp for the dual speed hydro.
/ Grand L 4240 for Grapple Work #28
+1. :thumbsup:
Giving up the 8 hp has been my only concern about trading he MX for the 4240, but I really don't think I will miss it since the only PTO work I plan to do is using a 6ft bush hog.
I did try out all of the HST+ features on the 4240 while test driving around the dealers lot. i liked them and thought they were cool and all, but didn't really think they would be that beneficial. However, after spending some time on the MX HST, I can now see where those additional features would actually be used, especially the extra High Low within each range and the ability to easily shift between them on the fly.
/ Grand L 4240 for Grapple Work #30
You should be fine with a 6ft brush hog on a 4240.
/ Grand L 4240 for Grapple Work #31
I think a 4240 would handle a 6 ft brush hog just fine.
/ Grand L 4240 for Grapple Work #32
Great pics! How much does your grapple weigh? I don't think I would ever need to lift anything more than what you are lifting in that picture :thumbsup:
I stuck with a 66" grapple to save weight, and I believe that it is around 680#. So far I haven't latched on to anything I couldn't move. I too have my rears ballast with Rimguard. That helps a ton. Well actually 1298# not a ton. :laughing:
/ Grand L 4240 for Grapple Work #33
I have an L 4240 HST+ with grapple and love what it does. Sometimes scary, but not for lack of power, but rather what it will lift and traversing uneven terrain
/ Grand L 4240 for Grapple Work #34
I run a 72" rotary mower behind an L3430 and while its a slow go at times, it works pretty well for the light mowing work in the flat pasture where I use it.
I also use a grapple on the L3430 and it has the loader one series down from the L4240, so I think the L4240 will work out well. While there have been times the I wish I could pick up more with the grapple, there have been an equal number of times that it picked up what I wanted to onlyto leave a rutted trail as the front wheels dug in due to the weight. Sometimes more grapple and lift means just more ruts to fix...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
207272 (A52708)
207272 (A52708)
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
