3boys865
I do own a L4240 HSTC,don't have a full grapple but a thumb and tooth-bar on the HD bucket.Works well for me but your 600# grapple would limit your lifting a bit.As far as power;shouldn't be a problem with the HST+ and auto throttle.
Ballast correctly and go to work.
The grapple is a little heavier than I wanted, but it is very well made and offered features that I really wanted. The 72" std bucket weighs about 320lbs so the grapple does cost me about 300lbs of lift. I was able to work with the grapple for about 1 hour clearing and moving brush. Seemed to work great with the limited amount of time I have been able to use it so far. I think the loader on the L4240 should be pretty comparable to the MX5100's so I don't anticipate that I would lose lift capacity, just 8 HP. Not sure if losing the HP will have much if any affect on the work I am doing with the grapple. The MX5100 does have a beefier front axle and wider R4 front tires, which in theory should help with FEL type applications. Don't know if it would be enough to notice a difference compared to the L4240 though...
