RDrancher's Photo Thread
/ RDrancher's Photo Thread #161
two bit - These are rentals they wanted to get them repaired inexpensively.
By "wash out", do you mean concrete wash out?
Yes, concrete wash out. I had some put down on a driveway years ago and it lasted well. Sold the place long ago and haven't been by to see if it's still holding up. Seemed like a good fix.
I usually don't use cement based materials for driveways. Nothing wrong with the product, but the feedback I've gotten from customers is the level of dust compared to a limestone or granite aggregate. I've never noticed a difference, but around here I can get limestone at close to the same price as recycled concrete so I don't bother with it much. I will say that recycled concrete and recycled asphalt are the easiest aggregates to grade.
/ RDrancher's Photo Thread #163
Seems I recall that after the wash out set up there was no noticeable dust. I can't recall what the cost was when I had it put in that DW years ago but it was cheap or I wouldn't have used it. :laughing:
Well, send some of that stuff over this way and I'll get to selling it! :D
/ RDrancher's Photo Thread #165
Well, like I said I haven't seen it in several years. I was commenting not so much on the quality of wash out as on my being cheap.
You are doing excellent with what you're using. :thumbsup:
I got a tip yesterday about a start-up concrete batch plant in the area that also had a bunch of crushed, screened asphalt, crushed concrete and select fill dirt. After some vague directions and a few wrong turns, I finally found the place. The owner's a pretty interesting guy. He started and owned two batch plants, sold them both and tried to retire both times, but kept running out of money. This new venture is called Last Chance Concrete. Like I said...he's a pretty interesting guy.
Well...TODAY was Monday!
Started out grading out a gravel driveway and ended up spending the rest of the day getting my tractor to the dealer. My NH was dead in the driveway with the bucket and BB on the ground. I picked up a Kubota MX4700 rental to get the NH outta there and finish the job up tomorrow. Of course...while I was trying to figure things out with Jinman on the phone...the gravel shows up. A special thanks to Jinman for running through what may have caused the breakdown with me and for the moral support!
This is NOT how you should transport a tractor. Loader wedged up off the deck and strapped down to keep the wedges from bouncing out, and the BB strapped up to the ROPS...and down to the trailer. You do what you gotta do...
Here are the loader arms wedged up with 1x3 stakes I had in the truck. It held (barely) for the trip to the dealership.
You know, it just dawned on me how thankful I am that this happened today. Since it's MLK day, my boy was out of school and went to work with me. This would have been a much bigger problem if it had happened tomorrow, when I'll be working alone again. :thumbsup:
/ RDrancher's Photo Thread #169
That sucks. Fuel problems or ?
Thinking that the shaft in the injector pump may have broken. I'll know for sure tomorrow after the service guy checks it out. Hoping for something small.
/ RDrancher's Photo Thread #171
About how many hours do you have on it?
I wish you luck on the small part! Nothing ever turns out that way for me.
I recently had to replace the injection pump in my truck and now it won't start cold. Pretty sure it's leaking fuel pressure somewhere but can't find any leaks. Makes me mad.
Thanks. Its around 2300 or so. I've dodged the bullet with this tractor quite a few times. Stuff diagnosed as spendy repairs turned out to be relatively inexpensive fixes. We'll see about this one, but I'm not too optimistic.
/ RDrancher's Photo Thread #173
Well, good luck, whatever it is.
You must be living right to be fortunate enough to have help with you when it broke down. :thumbsup:
Hope you get back up and running soon.
/ RDrancher's Photo Thread #174
John, the injector pump is run by lobes on the engine cam. It doesn't have a drive shaft or cam of it's own. I think if the cam was not turning due to something in its drivetrain, you would likely have had the engine lock up. I think the real possibility is that the rack is stuck in the off position. When you removed the c/o solenoid, the rack should have shifted, but it did not. I suppose it could be a problem with the governor linkage, but that will normally result in engine runaway or over-revving. I don't think there's a problem inside the injector that would have caused this on all three pumps except if the rack is out of position and the pump is remaining in cutoff. I guess Glenn at McMasters will let you know what he finds, but if I had to guess, I'd guess a stuck control rack.
Thanks for the info Jim. The shop was pretty full when I dropped off the tractor, so I'm going to let Glenn have another day before I bug him too much.
Finished up the the driveway today with the Kubota MX4700.
I don't like the tractor much, but I do like the 1000lb Gannon BB. Just wish it didn't have that danged tailgate.
/ RDrancher's Photo Thread #177
Doesn't the tailgate have latches so you can pin it fixed? Both of my blades have flaps that allow the inner blade to dig and the rear blade to float. Mine also pin down for extra spreading, but I usually just let them float.
Yes, it had the pins to secure it, but the nuts were rusted onto the studs so bad that I thought I'd twist the threads off trying to remove them. I sprayed them with some PB Blaster when I got home, so we'll see if they move better in the morning. Personally, I don't like a floating tailgate for gravel work, especially pure stone. Since gravel is what I work with most of the time, I could do without the tailgate just fine. Also, I've found that when back-blading most materials the non-floating tailgate BB's seem to roll the material over and mix it better too. It's just a personal preference. Today when I back-bladed to catch the little nooks and crannies, the ledge behind the floating blade kept picking up stone and then depositing it in the street. Extra cleanup work = no happy Johnny.
Another little driveway expansion and topping job.
Making a mess so I can fix it.
Did some grading, and wheel rolled it. Then ripped up the existing base and spread it over the whole area and wheel rolled it again.
Then topped it with road base and wheel rolled it again.
I dodged the bullet once again Jim.
Glenn had them remove the injector pump and they found the problem right away. When the injector shop (who's name I shall never mention again) replaced all of the o-rings and washers in the pump they didn't put the linkage pin for the rack on correctly. The pin fell out so the linkage wasn't even hooked up. After they hooked it back up they ran a pressure test and found that the lift pump was pretty weak, so they replaced that too. Whew!
Johnson 3pt 12' High Speed Disc Harrow (A64119)
Johnson 3pt 12'...
Kawasaki STX-12F (A64127)
Kawasaki STX-12F...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A61574)
2022 21ft Scout...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
