New Tractor
/ New Tractor #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
I currently have a Farmtrac 3130 with a FEL and a 3pt backhoe. I love the tractor it can lift about 1400lbs with my front pallet forks. One of my friends has offered me a good amount of money for it so I 'm going to sell it to him plus I'm looking at getting a sub mount backhoe instead of a 3pt system. Any thoughts the Kubota L 3800 can it lift close to what the farmtrac can .
thanks
/ New Tractor #2
thanks
Here is your specs
Loader type: Kubota LA524
Height (to pin): 94.3 inches [239 cm]
Dump clearance: 76.2 inches [193 cm]
Dump reach: 20.2 inches [51 cm]
Dump angle: 40
Reach at ground: 63.7 inches [161 cm]
Rollback angle: 31
Breakout force (at pin): 2,462 lbs [1116 kg]
Breakout force (at 500mm): 1,874 lbs [850 kg]
Breakout force (bucket): 2,215 lbs [1004 kg]
Lift to full height (at pin): 1,131 lbs [513 kg]
Lift to full height (at 500mm): 855 lbs [387 kg]
Lift to 1.5m (at pin): 1,490 lbs [675 kg]
Lift to 1.5m (at 500mm): 1,182 lbs [536 kg]
Raise time to height: 3.5 s
Bucket dump time: 1.7 s
Lowering time: 2.3 s
Rollback time: 2.2 s
/ New Tractor
Thanks - I was wondering if anyone that owns a L3800 can tell me how much it actually can lift with a set of pallet forks. I hear that Kubota rates their specs on the low side and Mahindra rates on the high side.
Thanks
/ New Tractor #4
i had an l3800 i traded for 7040su that will lift a 1 ton skid if ita 2000ibs on the skid i lift 2 the wieghted 2500ibs its was a chore i gave up on tractors trying to lift what i want to lift unless you to step up to a 100hp tractor i think you would not be happy with forks on an l3800 i hated that tractor maybe an l39 tlb is another one to look at that compares closer to my 7040 they are 32k new i would look at used good luck in your tractor search
/ New Tractor #5
I don't have an L3800 but they are very nice tractors. If you plan on moving that kind of weight often you might consider the L4600. It has a much stronger loader but still has a reasonable price.
/ New Tractor
thanks
/ New Tractor #8
I think the specs are what the tractor can lift safely and reliably.
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
