More info on my engine
/ More info on my engine #1
AroniaFarmer
Sioux City IA
TYM T603 52' Ford 8N
Hi everyone. I am trying to get some more information on my Perkins/cat engine. It is a four cylinder 60 hp, and runs very quiet and smooth. I have 170hours on it so far. Are there any concerns that I should have with this engine? When it was newer ( around 50 hours) it over heated bad. Never totally got into the red but I've been thinking about it lately Now I know that I have to blow the radiator out every once in a while. Other wise it's been goodagoodengine. Could I have warped anything by over heating I
AroniaFarmer said:
Hi everyone. I am trying to get some more information on my Perkins/cat engine. It is a four cylinder and runs very quiet and smooth. I have 170 hours on it so far. Are there any concerns that I should have with this engine? When it was newer ( around 50 hours) it over heated bad. Never totally got into the red but I've been thinking about it lately Now I know that I have to blow the radiator out every once in a while. Other wise it's been goodagoodengine. Could I have warped anything by over heating I
Wow my computer wasn't happy about that last sentence. Sorry about that haha!
/ More info on my engine #3
You didn't say which model engine. Cat/Perkins makes a lot of 4's, now up to 175 HP on the top end and I don't remember on the bottom. Smaller ones are built on license from Shibura and those can be a bit iffy. I have one of the smallest, a 3 cylinder, in my mini-excavator. Radiator plugs pretty easy - there isn't a lot of extra cooling system room available in such a small machine. Mine has been in the red several times before I caught it and I haven't had any noticeable problem - I have close to 1,500 hours on it now. Probably not a good sign that Cat as gone to Kubota engines in their new skid steers, mini-excavators, and compact wheel loaders, but it may just be a sign they were having trouble meeting emissions, have to re-engine every product in their lineup, and they could reduce development by using somebody else's engine. If I were you I really wouldn't be greatly concerned because there s a margin between start of red and oops, there is a problem. Watch your oil consumption, change your oil if you feel you may have cooked it, and go on. My little 3 cylinder uses a quart about every 50 hours which is a bit high but my engine has always had a lot of blow-by out the draft tube, especially after letting it sit idling for a long time.
Thanks for the reply. I was a bit worried about oil consumption but I guess that a little usage here and there isn't the end of the world. Do you think that they are good engines? Other than the radiator problems so far its done everything that I have asked for it to do. I cannot remember if I changed the oil for the first time before or after the over heat. But I think that it is about due for its 3 change. Right now it has a wix filter in it and mobal 1 full synthetic turbo diesel oil in it.
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
John Deere 1025R (A62177)
John Deere 1025R...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2021 Case TV450B (A64126)
2021 Case TV450B...
