Inexpensive diesel fuel tranfer tanks
/ Inexpensive diesel fuel tranfer tanks
Whats better than this. Some grea ideas here..Thanks to all....... Randy
/ Inexpensive diesel fuel tranfer tanks #12
For gravity feed, put a fuel rated valve in 1 of the bung holes, fill up using the other, and open the other partially to allow air in while fueling. Also you can get stick on DOT plackards that are 4" square and place on both sides and the top to be legal. Just FYI, anything that takes the vehicle's capacity over 100gal is technically hazmat and MUST be labeled so. and there are different labels for gas and diesel so make sure it is labeled correctly. Flammable 1203 is gas and 1202 and 1993 are diesel. So make sure those of you with the 275gal totes have them labeled all 4 sides to PYA.
/ Inexpensive diesel fuel tranfer tanks #13
That red fuel station is pretty much what i'm looking for. But not having any luck finding one. Any idea who makes it?
Thanks Tom
/ Inexpensive diesel fuel tranfer tanks #14
bet you could make one from an 'air up' tank.. and be in it for 1/3 the price.
/ Inexpensive diesel fuel tranfer tanks #15
I found the red tank at northern tool for $144.00
I also found a 50gal steel transfer tank on Craigslist. Going to look at it after work.
/ Inexpensive diesel fuel tranfer tanks #16
yep.. commercially they are pricey.
/ Inexpensive diesel fuel tranfer tanks #17
I use four 15 gallon poly barrels I got for free from a dairy farmer. Painted them yellow and stenciled on diesel on the side. Then bought a rotary tuthill hand pump and a transfer hose from Amazon. This allows me to have up to 60 gallons of fuel on hand for my pto generator in case of emergency and refill them independently.
/ Inexpensive diesel fuel tranfer tanks #18
If you go the 55 gallon drum, they make a caddy for them that fastens on to the rim of the steel barrels and allow one man to tilt it on its side and then upright it if needed. They have 2 wheels on the edge so you can upright it, roll it to wherever you want and then lay it on its side. THE 1" and larger 2" bung accepts standard pipe threads so you can insert a pipe nipple and a threaded valve in one of the bungs and use the other to vent. McMaster Carr would carry them, but you would still need to build a stand for it to set higher than your tractor so that might not be practical.
Simpliest is just the get a drum of the size that you want, fill it at a station and use a hand pump that fits in the 2" bung. For a few $$$ more you can get a 12 volt fuel pump and power it off your tractor battery.
My fuel station is a 105 gallon rectangular tank that I mounted swivel rollers on and a 12v 15 gpm Filrite pump. I power it with a standard sized battery (650 CCA) that I keep charged with a battery minder. The pump has a 15 micron filter installed on it, then a 25 foot hose with auto-shut off nozzle just like the service stations so I never spill any fuel. I have $350 invested in the tank, hose set up from a Craigslist post and $68 for the battery to power it +$10 for the battery charger. IT is worth the $78 for me not to have to raise the hood of the tractor each time I fill. I drilled and tapped the post to permanently attach the pigtail leads for the charger but still use the alligator clips to hook up the pump. I can roll the tank easily even when full if needed. I used to keep it in back of my shop and then roll it to front for filling but now I have an addition on my shop for my boat, lawnmowers and fueling station right by the door so I just pull up, raise the garage door, fuel and go.
Bulk fuel is delivered straight to my tank from my local distributor. I have to have 150 gallons minimum but he is happy to split the delivery with me and my brother in law. I could just make it to the total by myself if both tractors were empty and my lawnmower and I used a couple of plastic containers.
/ Inexpensive diesel fuel tranfer tanks #19
I have used a hose threaded into the 1" bung of a horizontal poly drum for gravity-fed watering, but I wouldn't trust it with a solvent which would make a serious mess if it leaked.
/ Inexpensive diesel fuel tranfer tanks #20
Well after work I went and looked at the steel transfer tank. It appears to be around a 50 gal tank. I was able to get it for $125.00 VS. the $144.00 for the red 15 gal tank. Now I need to get it plumbed up and a hose with ball valve. Put some 4 in tubing under it for my forks and i'll be all set.
Thanks for every ones help and ideas.
2000 Kubota KX61-2 (A60462)
2000 Kubota KX61-2...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
DEUTZ MARATHON...
JIB Wheel Loader Forks (A60462)
JIB Wheel Loader...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
