Kubota Quick Coupler
/ Kubota Quick Coupler #1
Mac25
Danville, IN
Kubota B2320 HST with LA 364 FEL
Just finished installing the Kubota Quick Coupler on my B2320 w/ LA 364 FEL. Fit like a glove and gives me a little more versatility with different attachments. Total price was $298 with freight.
/ Kubota Quick Coupler #2
Awsome! I think I'm going to have one of those too.
/ Kubota Quick Coupler #3
That will be a great time saver.
/ Kubota Quick Coupler #4
Where did you but it?
Edwards Equipment in Danville, IN
Sent from my iPhone using TractorByNet
/ Kubota Quick Coupler #6
What is the measurement between the inside and outside plates of your bucket? How far apart are the holes in the bucket?
Wondering if that would fit on our B7500 which (IIRC) has the LA302 FEL installed... Would be great to be able to easily switch to a set of forks.
Aaron Z
Aaron Z
I will have to get back to you on the measurements as I am not home right now.
No rush, will probably be spring before we get one, but for the price, it would probably be worth it...
Aaron Z
If i understood what measurements you needed, they are as follows...the inside to inside measurements between the two welded "c" channel brakets on the bucket are 26 9/16, outside to outside is 32 1/2. The inside to inside of the "c" channel itself is 2 7/16. The approximate measurement from center of pin to center of pin is 7 1/16. That is the upper and lower pins on the bucket, not the ones for the cylinder and loader arms. Hope this helps
/ Kubota Quick Coupler #11
FWIW, here is a list of a few Kubota Quick Couplers and list price. I am sure there are more than I have listed. I can't remember if I found the list on line or here on TBN.
B1658 for LA364/LA504 List $279
B2365 for LA403 List $279
L2216 for LA514 $432
L2226 for LA724/LA844/L854 $443.00
M1802 for LA1002 $505
Landoll 18' Tilloll (A66285)
Landoll 18'...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A64553)
2006 Generac...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
