Tiller Tiller info
/ Tiller info #1
OrangeToys
SW Missouri
2016 Kubota M7060HDC
Looking to put a tiller behind my MX5100 and i found a new Bush Hog RTS74 at a dealer in town for $2300, they say it is a 2010 model. So I'm needing your opinion on what to look for in tillers. And any info on this one I've found.
Thanks
/ Tiller info #2
Thanks
That seems to be a pretty light duty tiller in my opinion weighing in at only 525 pounds, featuring only 4 blades per flange and a chain drive. On the Bush Hog website, it says that a slip clutch is optional. I believe that a couple of the best tillers on the market for the money is the King Kutter II and the Phoenix T10-74" model. Both of these gear driven tillers feature 6 blades per flange, weigh over 700 pounds, come standard with a slip clutch, and are in the same price range as the Bush Hog you mentioned(brand new from the factory). Our tillers ship free to a business or supporting freight terminal within 1,000 miles of Newton, NC. If you're outside the free shipping zone, freight is generally very reasonable. Click on the links above to see the details, prices and product videos.
I hope this helps.
Travis
/ Tiller info
I like the king kutter, but can't find if it runs forward or reverse
/ Tiller info #5
The ones on our website are forward rotating however they do make a reverse rotation tiller for about $150 more. Some people like reverse, some don't. Reverse rotation tillers are known to pulverize the soil very fine so it is a disadvantage in our red clay here in NC. If you till it too fine here, you have red concrete after it rains!! With a forward tine tiller, if you want your soil finely tilled, just lower the tailgate and go slower or make more passes. Here's a pic of the reverse rotation tiller:
/ Tiller info
2 questions
Chain vs gear
And
Forward vs resverse
/ Tiller info #7
I have the King kutter from TSC, same as EA, I cant say enough good about it! I use a forward rotation, and I have no experience with reverse ones.
Good luck.
PS I paid $1400 for my 60" which is too small for you likely.
/ Tiller info #8
2 questions
Chain vs gear
And
Forward vs resverse
It depends on what you are getting into. Forward,,, for soft ground, it will tolerate rocks without too much frustration, and is great for incorporating deep mulch.
Reverse,,, for hard compacted ground with few rocks, they do a miserable job at incorporating mulch because it just pushes it forward into a big ball under the 3PH, and rocks can be troublesome. If you want to hire it out, this is the one you want. It seams a lot of my new costumers call after trying it themselves and run into a problem of some sort.
/ Tiller info
Yes i will be doing it for business and pleasure but more for the added $$$$ and for another service for me to offer
/ Tiller info #10
Get the forward rotation, and gear drive for your size tractor.
Just be advised that the tiller will pile the dirt behind the tiller, and take it from the other end of the row. Try to get customers to set up the garden so you have complete access to all 4 sides(including turning) at all times. After you till a few times you will see what I mean.
/ Tiller info #11
Being able to get in and out on all four sides is a luxury that is seldom available when tilling for hire. There is usually something in the way ; bushes, fence, building, flowers, property line, etc. Besides, a reverse tine tiller is advertised as a one pass tiller and it generally works out that way. Occasionally I'll till a couple of gardens with a fence on all four sides and have to drive through a small gate to get in.
/ Tiller info #12
I use a forward rotation tiller with slip clutch and 6 tines/rotor with chain drive. This is a Deere 673 72" width and it does a great job for me, I have hit some large rocks and on a couple of occasions has stopped the tiller but no harm done. What small stumps that were missed in clean up the forward rotation will climb over without damage. in most cases the forward tine rotation will climb over an obstacle whereas the reverse tine will hang up. For hire i would use the forward rotation.
/ Tiller info #13
bigtiller;3145742[B said:
]Being able to get in and out on all four sides is a luxury that is seldom available when tilling for hire[/B]. There is usually something in the way ; bushes, fence, building, flowers, property line, etc. Besides, a reverse tine tiller is advertised as a one pass tiller and it generally works out that way. Occasionally I'll till a couple of gardens with a fence on all four sides and have to drive through a small gate to get in.
I know what you mean. One neighbor I till for I can only do 3 sides. The garden is about 100 feet long, and 30 feet wide. The long passes pull the dirt to one end of the garden.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2015 Kenworth T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 Kenworth T680...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2018 INTERNATIONAL 4300 4X2 BOX TRUCK (A59906)
2018 INTERNATIONAL...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
