Tiller Tiller info
/ Tiller info #1
OrangeToys
SW Missouri
2016 Kubota M7060HDC
Looking to put a tiller behind my MX5100 and i found a new Bush Hog RTS74 at a dealer in town for $2300, they say it is a 2010 model. So I'm needing your opinion on what to look for in tillers. And any info on this one I've found.
Thanks
/ Tiller info #2
Thanks
That seems to be a pretty light duty tiller in my opinion weighing in at only 525 pounds, featuring only 4 blades per flange and a chain drive. On the Bush Hog website, it says that a slip clutch is optional. I believe that a couple of the best tillers on the market for the money is the King Kutter II and the Phoenix T10-74" model. Both of these gear driven tillers feature 6 blades per flange, weigh over 700 pounds, come standard with a slip clutch, and are in the same price range as the Bush Hog you mentioned(brand new from the factory). Our tillers ship free to a business or supporting freight terminal within 1,000 miles of Newton, NC. If you're outside the free shipping zone, freight is generally very reasonable. Click on the links above to see the details, prices and product videos.
I hope this helps.
Travis
/ Tiller info
I like the king kutter, but can't find if it runs forward or reverse
/ Tiller info #5
The ones on our website are forward rotating however they do make a reverse rotation tiller for about $150 more. Some people like reverse, some don't. Reverse rotation tillers are known to pulverize the soil very fine so it is a disadvantage in our red clay here in NC. If you till it too fine here, you have red concrete after it rains!! With a forward tine tiller, if you want your soil finely tilled, just lower the tailgate and go slower or make more passes. Here's a pic of the reverse rotation tiller:
/ Tiller info
2 questions
Chain vs gear
And
Forward vs resverse
/ Tiller info #7
I have the King kutter from TSC, same as EA, I cant say enough good about it! I use a forward rotation, and I have no experience with reverse ones.
Good luck.
PS I paid $1400 for my 60" which is too small for you likely.
/ Tiller info #8
2 questions
Chain vs gear
And
Forward vs resverse
It depends on what you are getting into. Forward,,, for soft ground, it will tolerate rocks without too much frustration, and is great for incorporating deep mulch.
Reverse,,, for hard compacted ground with few rocks, they do a miserable job at incorporating mulch because it just pushes it forward into a big ball under the 3PH, and rocks can be troublesome. If you want to hire it out, this is the one you want. It seams a lot of my new costumers call after trying it themselves and run into a problem of some sort.
/ Tiller info
Yes i will be doing it for business and pleasure but more for the added $$$$ and for another service for me to offer
/ Tiller info #10
Get the forward rotation, and gear drive for your size tractor.
Just be advised that the tiller will pile the dirt behind the tiller, and take it from the other end of the row. Try to get customers to set up the garden so you have complete access to all 4 sides(including turning) at all times. After you till a few times you will see what I mean.
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
John Deere 5045E for sale
John Deere 5045E...
2022 John Deere 5055E (A60462)
2022 John Deere...
Manure spreader for sale
Manure spreader...
2013 Case 850L (A60462)
2013 Case 850L...
KJ K2030 20'x30' Metal Garage (A60463)
KJ K2030 20'x30'...
