12v Rocker Switch
/ 12v Rocker Switch #51
Look for a "Carling" switch.
I used a "Contura" for my LED install. They are Waterproof, marine grade. They are also the OEM for ALOT of the major tractor and boat manufacturers.
Not cheap (About $15 per, depending on model) but quality.V-Series: Contura II & III | carlingtech.com
You can also get the switches with function indicators:
I mounted mine to the dash:
/ 12v Rocker Switch #52
Those look like the same switches we have on all the fire trucks.
/ 12v Rocker Switch #53
Very likely are. They are quite common for OEMs. Used on alot of heavy equipment too. They have a few different designs for the operators. They arent the cheapest or easist to find, but they work very well.
/ 12v Rocker Switch
I found this switch, I am still going to search. I was hoping to find a rocker switch because I thought it would be more user friendly.
I was about to order this switch then I realized it is only good for .1 amp DC.:pullinghair:
/ 12v Rocker Switch #56
You should really consider the Contura switches if your going to be exposing it to the weather and want it to last. They are a bit large... but they are quality.
/ 12v Rocker Switch
Since I planed on mounting the switch in the light and it has a rubber housing I thought the smaller hole I had to poke in it the stronger it would stay. I would hate to poke a hole in the tractor to mount the switch.
/ 12v Rocker Switch #58
Yeah.. I know exactly what you mean.. It was hard to cut the hole in my dash, believe me!! But in the end I figured it would be worth it, and it was!.. Even if I had to remove the switch at a later date, the whole plastic "dashboard" that I drilled into is only $30 to replace with a new one
/ 12v Rocker Switch #59
For $30 I would have an extra dashboard hanging on the wall, before it's discontinued.
/ 12v Rocker Switch #60
I found the dash wasn't all that convenient that's why I mounted them behind the HST gear lever. Must easier to reach.
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
CAT 930M (A58214)
CAT 930M (A58214)
2017 John Deere 6120E (A53317)
2017 John Deere...
2022 KUBOTA SVL75-2 SKID STEER (A62129)
2022 KUBOTA...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
